Speedo not working
The Tot
PostPosted: 17:04 - 13 Dec 2005    Post subject: Speedo not working Reply with quote
Hi guys,
I noticed when i came back from the peak district that my speedo on my bike was NOT working. I checked the old speedo cable and was intact. Consequently i cleaned the ends of the cable and reattached. No use.
I bought a new speedo cable and it still failed to run.
Anybody have any other suggestions as to what maybe wrong?
Also, is a working speedo necessary for MOT?
Never argue with autism
mchaggis
PostPosted: 17:44 - 13 Dec 2005    Post subject: Re: Speedo not working Reply with quote
Yes.
Is it driven from the front wheel? I am assuming so. Get the front wheel off the ground, disattach the cable from the bottom and look in it's hole. When spinning the front wheel, you should be able to see the drive 'peg' turning. If that is, it's a problem with the top end.
If it isn't, it's a problem with the speedo drive at the wheel. Take the wheel off and explore. Any problem should be fairly obvious as it is a very simple system (a pair of tongues driven by the front wheel, driving through a pinion and worm gear, which spins the peg, spinning the cable.)
I must not be a troll...
Mmmm, Guinness
romperstomper...
PostPosted: 18:17 - 13 Dec 2005    Post subject: Reply with quote
mine often stops working in damp or wet weather then starts again when its dried out !
Yeah I know !
RSheale
PostPosted: 22:53 - 13 Dec 2005    Post subject: Reply with quote
what bike do you have!?
if its from the front wheel the i guess the speedo drive could of had it and you need to replace that,
other than that i have no idea?
Slinn84
PostPosted: 02:57 - 14 Dec 2005    Post subject: Reply with quote
another posibility if it turns out not to be the speedo drive is the clock housing
the cable spins round and turns the clock housing gears to move the speedo dial and turn the mileage clocks
this could have seized up
The Tot
PostPosted: 09:23 - 14 Dec 2005    Post subject: Reply with quote
My suspicion was the speedo clock housing, cos i couldn't tell whether it rotated freely or not.I know for sure that the front wheel spindle peg rotates cos is shoved the old cable in and walked it.
The speedo clock does seem a tad loose which means that all i can do really is to get a digi replacement.
mchaggis
PostPosted: 15:40 - 14 Dec 2005    Post subject: Reply with quote
Take it to pieces and investigate the clocks before you fork out for another though, it's entirely possible that it a screw or two has come loose.
Mmmm, Guinness
The last post was made 20 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.8 - MySQL Queries: 13 - Page Size: 53.4 Kb
