will it work?
Type_Mo
PostPosted: 13:42 - 14 Dec 2005    Post subject: will it work? Reply with quote
Cant afford a 17cc bore kit, so if i got the 170cc piston can i get my barrel re-bored?
will it run ok?
sickpup
Old Timer
PostPosted: 15:01 - 14 Dec 2005    Post subject: Reply with quote
No. Not enough meat.
satans_BIG_helper
PostPosted: 17:58 - 14 Dec 2005    Post subject: Reply with quote
I assume your asking wether a standard 125cc barrel can be bored out to 170 cc ??
If so
"computer says no" Laughing (been waiting to use that lame line for a while now)
There is no where near enough room to bore out a 125 to 170... its like roughly a 40% capacity increase and the most a normal barrel can be bored out is by 2mm which is not much :S
Just stick with the 125 and save up for the 170 kit or buy a bigger bike Question
Andy C
Tree Seeking Missile
PostPosted: 18:29 - 14 Dec 2005    Post subject: Reply with quote
yea, if not done right will make it really unreliable and will need new gears if you want higher top speed, really no point and you havnt passed yet!!
Type_Mo
PostPosted: 19:01 - 14 Dec 2005    Post subject: Reply with quote
Cos i heard about someone boreing out a 100cc moped upto 125?
Andy C
PostPosted: 19:05 - 14 Dec 2005    Post subject: Reply with quote
yea im sure you could bore it out a bit but you make ruin its reliability, also everything on your bike was built for a 125cc not a 170cc, parts could fail if it was uprated, im sure most wouldnt i just think getting a igger bike so much of a better idea, esp when 2ts ate involved Thumbs Up
Jack_Cheese
PostPosted: 19:13 - 14 Dec 2005    Post subject: Reply with quote
I wouldn't buy a big bore kit, you normally keep the standard head and crank case, though a dt125 may require a new head. The extra power will require a reinforced crank shaft and con rod (or it is at least a good idea to buy and fit a strengthened one) although it will run on a standard one. It will also put more stress on the bearings, and you'll have to increase the jet size or get a bigger carb. Replacing the chain and altering the final drive ratio would be a good idea, too. A new exhaust may be needed aswell.
If you can't do the majority of the above, especially the carb and exhaust, then you will probably become acquainted with "Bang Fizzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz"
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
jonnay
PostPosted: 21:50 - 14 Dec 2005    Post subject: Reply with quote
My mates DT125 (pic of it on my website) had a 170 kit on it, and that went like fook Very Happy It was only a field bike, but my god, it flew, and wheelied for England.
He left the gearing as standard too, for accelaration Thumbs Up
Don't know about reliabilty, but they seem pretty indestructible Mr. Green
::'04 Yamaha Jog:: || ::'01 Honda NSR:: || ::'00 Suzuki Swift:: || ::'89 Swift GTi:: || ::'96 Swift Poverty Spec:: || ::'92 Swift GTi::
The last post was made 20 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 58.59 Kb
