help with cg
rvf-stef
PostPosted: 16:22 - 14 Dec 2005    Post subject: help with cg Reply with quote
Please help me.
I turn the key on my cg and the lights dont come on (neutral lights, indicator,horn doesnt work,headlights) and u cant start it. (its kick start) after about 20 seconds the lights come on and everything is normal.
turn the key off and on again same problem. It doesnt always do it and somes times the time the lights come on is about 2 seconds. any idea of the problem?
satans_BIG_helper
PostPosted: 17:54 - 14 Dec 2005    Post subject: Reply with quote
Possibly a dodgy battery connection mate... CG batteries are not fantastic to start with and if one of the connections is dirty/loose it could cause the problem you have ?
Or a dirty/loose ignition connector ? if one of these is loose or dirty it could cause the same thing... most likely a loose connection somewhere just check your battery terminals and see what condition they are in
cant think of much else on a CG that could cause this kind of problem as there is not much to go wrong on it really Confused
doggone
PostPosted: 18:18 - 14 Dec 2005    Post subject: Reply with quote
Could it be some sort of relay I wonder.
Knowlsey
PostPosted: 01:09 - 15 Dec 2005    Post subject: Reply with quote
what he said
mchaggis
PostPosted: 01:18 - 15 Dec 2005    Post subject: Reply with quote
It's most likely a loose connection or similar. Hit it. Smile That fixed the intermittent problem on the one I use now and again, though taking the battery out to charge it fixed it properly as the terminals got tightened properly.
I must not be a troll...
Mmmm, Guinness
PostPosted: 01:23 - 15 Dec 2005    Post subject: Reply with quote
Don't know if they would have a relay between the ignition switch and the ignition circuit on a CG125. I certainly doubt it on a slightly older one. More modern ones might have some safety interlocks but again, not so sure there would be a relay.
The state of charge of the battery should also make little difference to a kick start CG.
My vote goes for a bad connection in the ignition switch. Get with the WD40.
satans_BIG_helper
PostPosted: 13:03 - 15 Dec 2005    Post subject: Reply with quote
But make sure the ignition is switched off while your spraying WD40 onto battery terminals n other connectors....
as one little spark and it WILL set on fire ive seen it happen to a mate of mine who was spraying WD40 onto his battery where it had a loose contact it arc'd, sparked and took his eyebrows off Laughing
Could have been worse tho... Keep us updated on this Smile
The last post was made 20 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 52.82 Kb
