Fitting a new softlink chain
LeonClayton
PostPosted: 12:29 - 15 Dec 2005    Post subject: Fitting a new softlink chain Reply with quote
Any ideas.
have just fitted a new chain and sprockets, all gone well and chain is back together.
i now need to hammer the softlink so it will not come off. This is quite hard.
Is there a tool to do this for you. The softlink chain removal tool i have does not.
ideas?
Bezzer
PostPosted: 12:53 - 15 Dec 2005    Post subject: Reply with quote
Proper tool can cost a few quid, up to £100 if you want top notch. Those with a bit of experience do it using two hammers peening over the rivet head. If you haven't got the confidence to do that buy a split link for your chain, put it on then ride to a dealer/shop and get them to put the soft link on properly for you, only cost a couple of quid.
PostPosted: 13:14 - 15 Dec 2005    Post subject: Reply with quote
I push them on with a pair of mole grips and a nut.
Gradually close the grips in such a way as you are pressing the pin through the keeper plate, then undo them again, tighten the clamp a tiny bit and close them. Repeat this until you have pushed the pin through flush with the plate. Then place a small nut between the jaws of the grips and the pin to create a space to push it the last wee bit through.
Takes some time but works for me.
the grim reaper
PostPosted: 13:35 - 15 Dec 2005    Post subject: Reply with quote
If you decide to buy a chain rivetting tool, do NOT buy the M&P heavy duty 3-in-1 chain tool. Heavy duty, my arse, I snapped one and nearly took my own arm off because I had it under serious pressure to rivet the pin.
I bought one off Ebay which is better but not perfect cos the arm is starting to bend already.
Grim
LeonClayton
PostPosted: 15:40 - 15 Dec 2005    Post subject: Reply with quote
thanks for the advise.
I tried the 2 hammers and i must be shite. Ebay next then the dealer .
cheers
Leon
The last post was made 20 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 43.67 Kb
