Bugger!!
DukeRed
PostPosted: 17:49 - 17 Dec 2005    Post subject: Bugger!! Reply with quote
Sheared a bolt off while changing the oil filter. There's still another 4 left. Is that enough until next change?
Serves me right for being all "I never use torque wrenches."
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
DukeRed
PostPosted: 17:59 - 17 Dec 2005    Post subject: Reply with quote
Somebody must know if it's driveable. I need to get to N.London very soon and I hate the train/tube.
tatters
Exxon Valdez
PostPosted: 18:04 - 17 Dec 2005    Post subject: Reply with quote
does it leak oil with the engine runing?
never heard of an oil filter with bolts on.
All of mine have been spin on type oil filters...
tatters
Exxon Valdez
PostPosted: 18:05 - 17 Dec 2005    Post subject: Reply with quote
Some old bikes like Honda superdreams use a self contaied paper oil filter in a enclosure located in the sump.
tatters
Exxon Valdez
repeat post
Nb
PostPosted: 18:06 - 17 Dec 2005    Post subject: Reply with quote
How can changing an oil filter shear a bolt off? Is it like a sump pan type filter?
DukeRed
It doesn't leak but then it is just on tick over. I was worried that for hard use it would be put under pressure.
It's a paper style filter and has a housing that bolts under the engine.
Strange I thought as well.
Nb
PostPosted: 18:08 - 17 Dec 2005    Post subject: Reply with quote
Oil pressure does increase with engine revs... so it might be ok on idle but once its hot (oil gets thinner) it might leak out with nasty consequences. Is it sheared flush ?
DukeRed
PostPosted: 18:15 - 17 Dec 2005    Post subject: Reply with quote
Nope, bit further down. Still blocks the hole but that doesn't really mean much.
I fitted new seals so ....
tatters
Exxon Valdez
PostPosted: 18:18 - 17 Dec 2005    Post subject: Reply with quote
If it was daylight and you were only going on a short trip l would say risk it and have a look under the bike at every traffic light stop to make sure it was,nt pissing out.
l once rode a CB400N with a leaking base gasket (pissing out with oil) 60 miles with no problems (apart from oil all up my left leg). Laughing
DukeRed
PostPosted: 18:26 - 17 Dec 2005    Post subject: Reply with quote
Sod it, I'll see what happens.
MikeH
PostPosted: 18:29 - 17 Dec 2005    Post subject: Reply with quote
Get a sharp 3 - 4mm drill and drill the stump dead centre (use another bolt to gauge the depth to go) then slowly increase the drill size until you get to the size of the inner diameter of the threads where you will just start to reveal the threads in the ally. From there if your lucky you should be able to pick out the remaining thread and put a new bolt in. Takes ages to do but tis possible with patience and decent sharp drill bits.
Did it on a brake caliper on an old porker 968 when I sheared a bleed nipple off flush with the casting.
Otherwise take it for a run locally and give it some beans to see how she behaves under load, you'll probably find it'll be OK if you haven't over torqued the other three and twisted the plate.
Good Luck
Mike Thumbs Up
Busa Junkie
The last post was made 20 years, 276 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 77.24 Kb
