| numark1 |
 numark1 Scared of girls
 Posted: 19:40 - 16 Dec 2005 Post subject: DIY Servicing |
Taking my dads bike down to the garage tomorrow to get the tyres changed and want to do some servicing on it myself as i haven't taken a bike apart in a while.
So far i have thought of:
Spark Plugs
Oil Change
Coolant Change
A Clean (if i feel up to it)
can't think of anything else. It's due a service and i want to do as much as i can so i can be my dads favourite just before christmas.
Any other sugguestions?  |
| kawakid |
 kawakid World Chat Champion
| Teaman |
 Teaman World Chat Champion
 Posted: 20:38 - 16 Dec 2005 Post subject: |
break pads, break fluid,
pretty much everything you dotn need a macine for, (tyres)
you can do forks, fork seals really,, honestly and aslong as you have the confidence and common sence to buy a decent munual, either workshop, clymer or hains (at a push) you cant really go wrong,
must buy tools would be carb ballencing kits, if you have carbs
torque set
small shitty welding kit (just in case you have to make some odd tools, like i had to weld a bolt to a long piece of steel to take my forks appart)
faith in what you can do and a mate to phone up for advice (or bcf forums) is a must aswell ____________________ There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them. |
| doggone |
 doggone World Chat Champion
| riichy |
 riichy World Chat Champion
 Posted: 20:54 - 16 Dec 2005 Post subject: |
want to do mine too  ____________________ .......... PLOD ............ zx636 2004 |
| tatters |
 tatters Exxon Valdez
 Posted: 21:02 - 16 Dec 2005 Post subject: |
Don,t touch the Spark Plugs on a four-stroke bike like a ZZR600 unless they really need changing (causing troble) snapping the small spark plugs and ripping the thread out is very easyly done and a pain in the arse to sort out on a four-stroke. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| numark1 |
 Posted: 21:14 - 16 Dec 2005 Post subject: |
I took one out and its all rusted.
I was going to get him some of those iridium ones.
Brake pads have been done recently also the disks because my dad wore down to the metal and screwed the disks up.
He said it doesnt seem to ride properly any more. Done 50,000 miles since new in 5 years.
Any excuse to buy a new bike/car instead of sleep loads on one weekend.  |
| instigator |
 instigator Super Spammer
 Posted: 21:29 - 16 Dec 2005 Post subject: |
Adjsuting & Lubing throttle cable can make the bike feel a lot more responsive. If one of the spark plug ends is actually rusted, then I'd change them but would take a detailed look at them against a spark plug chart to see how the engine is running.
Then jsut do what you're planning, making sure you have the f*cking tools!!! (Things get ugly with me when I buy something and realise I need a seperate tool to use it ) |
| fuzz |
 fuzz World Chat Champion
 Posted: 12:46 - 17 Dec 2005 Post subject: |
| tatters wrote: | Don,t touch the Spark Plugs on a four-stroke bike like a ZZR600 unless they really need changing (causing troble) snapping the small spark plugs and ripping the thread out is very easyly done and a pain in the arse to sort out on a four-stroke. |
Surely checking the spark plugs before they start to give you trouble is a better practice?
If you're careful with them, you should be able to check them whenever you want without causing more problems. Hand tighten them, then a 1/8 turn with a spanner/wrench to seat it tight. If they're brand new plugs, give 1/4-1/2 turn.
Checking the plugs gives you a good indication of how the engine is running - too rich/lean, too hot/cold and hopefully you can rectify this before any problems occur. ____________________ https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800 |
| numark1 |
 Posted: 13:40 - 17 Dec 2005 Post subject: |
It's running a bit rich due to the harpoon exhausts. It sounds pretty fucked now though. I think its near the end of it's life.
50,000 miles is loads for a bike. |
| Guest |
 Guest Brolly Dolly
| Finglonga |
 Finglonga World Chat Champion
| numark1 |
 Posted: 17:56 - 18 Dec 2005 Post subject: |
It's a ZZR600.
Got some castrol oil, the best i could find at £35 for 4 litres. New spark plugs, oil filter and redex carb cleaner.
The plugs i took out were pretty fouled up and had rust on them
Probably not gonna do the oil filter because it looks like too much hard work and all of the kawasaki screws are rounding as soon as i look at them.
Also pulled a muscle in my back whilst doing it. Luckly i have 2 weeks off work for christmas now though.  |
| craigs23 |
 craigs23 Mr Muscle
| numark1 |
 Posted: 17:59 - 18 Dec 2005 Post subject: |
Got a haynes. Just want to do the basic stuff. It will be getting serviced at a garage soon just want to do some of it myself becuase its fun taking bikes apart.  |
| craigs23 |
 craigs23 Mr Muscle
 Posted: 18:03 - 18 Dec 2005 Post subject: |
That's how I started - doing it as a hobby with some supervision by Dad - I do most of the work on my bikes now  |
| numark1 |
 Posted: 18:06 - 18 Dec 2005 Post subject: |
Also its good to know that the job you are doing is being done properly rather than what the mechanic is doing. My friend found a screwdrive in the side of his zxr400 when he got it serviced.  |
| fuzz |
 Posted: 22:39 - 18 Dec 2005 Post subject: |
And also that the job(s) that needs doing are being done and nothing else that you could be charged for! ____________________ https://www.bikepics.com/members/fuzzbcf/
| Guest |
 Guest Brolly Dolly
| numark1 |
| tatters |
 Posted: 10:20 - 19 Dec 2005 Post subject: |
Its only four bolts to take the belly pan off and then the oil filter is right in front of you. piss easy to get the oil filter off by hammering a screw driver through it, and do the new one up as tight as possable by hand. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Klause |
 Klause World Chat Champion
 Posted: 13:35 - 19 Dec 2005 Post subject: |
If you need any help you know where I am. Please don't say the brake seals need doing  ____________________ Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie. |
| numark1 |
 Posted: 14:32 - 19 Dec 2005 Post subject: |
Im trying to get the airbox on now and its fucking pissing me off. Its much harder than last time and the carbs keep coming off even though i tighten them.  |
| Klause |
| tatters |
 Posted: 16:52 - 19 Dec 2005 Post subject: |
Get some washing up liqued around the rubber carb connectors on the air box, then they will slip on with ease. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
The last post was made 20 years, 37 days ago. Instead of replying here, would creating a new thread be more useful? |
