Four discs? How's that work?
DukeRed
PostPosted: 16:31 - 24 Dec 2005    Post subject: Four discs? How's that work? Reply with quote
https://beringerbrakes.com/4d.html
Can't figure out how they work. 4 pads or 2 pads?
Doh!
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
nick.h
PostPosted: 16:34 - 24 Dec 2005    Post subject: Reply with quote
4 pistons and 3 pads per caliper
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
DukeRed
PostPosted: 16:52 - 24 Dec 2005    Post subject: Reply with quote
Ah I see. Thumbs Up Very cool.
Teaman
PostPosted: 17:09 - 24 Dec 2005    Post subject: Reply with quote
woo hoo. gone are the days of not being able to pump your tyres up at the patrol station and struggling like buggery with the foot pump Smile
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
Rookie
PostPosted: 17:12 - 24 Dec 2005    Post subject: Reply with quote
$1600 for a front system! Shocked
sickpup
Old Timer
PostPosted: 18:01 - 24 Dec 2005    Post subject: Reply with quote
Its an old system, 8-9 years old.
Saw it years ago and the consensus was no improvement over a conventional system but extra weight.
selfdestructi...
PostPosted: 18:19 - 24 Dec 2005    Post subject: Reply with quote
spotted these on bsb bikes a couple of years ago.. a passing fad (bit like radial brakes)
Triumph Daytona 955i - Triumph Sprint Sport - Suzuki DR350ES
Luke_Retrofly
Silly Lesbian
PostPosted: 20:40 - 24 Dec 2005    Post subject: Reply with quote
I dont think radial calipers are a passing fad, they are the new gen Smile
Luke
Flounced - Long overdue
Fuck you bitch I'm in the top 10 list I can do the what the fuck I want!
Lee_367
PostPosted: 21:32 - 24 Dec 2005    Post subject: Reply with quote
They keep more of the weight towards the centre of the wheel which is a good thing. I'm sure i've seen them on a few endurance bikes.
?It?s mercy, compassion, and forgiveness I lack?not rationality.?
sickpup
Old Timer
PostPosted: 21:58 - 24 Dec 2005    Post subject: Reply with quote
Not really I'm afraid.
In total both discs have around half the circumference of a single radial disc which can be made to have a smaller swept area so having less mass and yet still retain a larger overall braking surface. Add in the fact that using a radial disc means you can use a thinner spoked, lighter wheel as there are no radial loads and any advantage soon disappears.
Then add in the point of greater mechanical advantage and you can have an even thinner swept area yet still retain greater braking ability.
Then remember that the heat from the disc is transferred into the rim and not the hub so bearings can be thinner as can the walls of the hub so saving even more unsprung weight.
As a radial disc will have a huge surface area it will also dissipate heat quicker so can be made thinner saving yet more weight.
I'll probably think of some more reasons later but you get the idea.
lilredmachine
PostPosted: 10:23 - 25 Dec 2005    Post subject: Reply with quote
it also looks wank.
DucatiEVO
PostPosted: 10:30 - 25 Dec 2005    Post subject: Reply with quote
I'm with him ^^^ Thumbs Up
aKa: Ducky
DukeRed
PostPosted: 12:59 - 25 Dec 2005    Post subject: Reply with quote
https://cgi.ebay.co.uk/gary-masons-2002-british-superbike-for-sale_W0QQitemZ4599051286QQcategoryZ9806QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I reckon they look pretty trick on this.
DucatiEVO
PostPosted: 13:47 - 25 Dec 2005    Post subject: Reply with quote
Nope still look wank! Wink
aKa: Ducky
mchaggis
PostPosted: 18:43 - 25 Dec 2005    Post subject: Reply with quote
You can have as many discs as you like with a wet multi-disc arrangment, commonly used in tractors etc. For a small radius you can pack in loads of discs and use the self-servo effect to ramp the braking torque right up.
I must not be a troll...
Mmmm, Guinness
Deano
PostPosted: 23:37 - 25 Dec 2005    Post subject: Reply with quote
those who think radial brakes are a fad are mistaken.
Radial calipers flex less than standard calipers which results in fade because some of the pots lift up and away from the rotors.
Radial calipers have been proven to stop up to 2 bikes lengths better than the old system. a small increase but definate one that is still a major benefit to racers and road users if they are used properly.
loply
PostPosted: 14:43 - 26 Dec 2005    Post subject: Reply with quote
Folks seem to be confused between "radial mounted discs" and "radially mounted calipers". The two are completely different things.
Radially mounted discs (one extremely large disc arouned the edge of the wheel) may or may not be a passing fad; They certainly work though, reducing weight and increasing braking force.
Yamaha SZR660 Caution to the wind, the throttle pinned!
NSR Mick
PostPosted: 22:36 - 26 Dec 2005    Post subject: Reply with quote
[quote="Deano"]those who think radial brakes are a fad are mistaken.
quote]
agreed but how many people who buy a bike with radial calipers would be able to tell????
its the pb effect, i.e. its got radial calipers so it must be good
Deano
PostPosted: 14:28 - 27 Dec 2005    Post subject: Reply with quote
@ loply: reducing weight ie is in the aspect of the wheels can be lighten further than they are today as the force from braking are less harsh on the spokes. So the wheels can be weakened by lightening the wheel and also you only need one disc compared to the norm of two.
@gsxrmick: that may be true but they still an improving from the old and don't cost the manufacturers more money to produce/redesign which i think is the problem with radially mounted discs.
loply
PostPosted: 18:09 - 29 Dec 2005    Post subject: Reply with quote
So if radially mounted discs are indeed superior, which I believe they are, then why aren't they fitted as standard to any mainstream bikes?
mchaggis
PostPosted: 19:29 - 29 Dec 2005    Post subject: Reply with quote
Because they're too much of a departure from conventional thinking. People need to see them fitted to MotoGP machines before they'll buy a sports bike with them on. For whatever reason, they aren't fitted to GP machines. I doubt money is really going to be an issue, but homologation rules and the question of whether they would really be good enough to work reliably under race conditions might be.
The weight saving in the wheel might not actually counter the increased weight of the rim-mounted disc. Using just a single disc and caliper (massively increased effective radius) might well improve that score though.
Mmmm, Guinness
The last post was made 20 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 110.36 Kb
