no power after 120ks
rg 250 freak
PostPosted: 11:34 - 27 Dec 2005    Post subject: no power after 120ks Reply with quote
heeelllppp
im having trouble with my 83 mod rg 250 goes hard then i change in to 5th gear at around 120 ks and it starts to die will slow right down to 80 ks but it can stay their till i changeback to 3rd or 4th can any one tell me what they think is goin on
please Confused
Full throttle all the way
Stevie GooGs
PostPosted: 11:39 - 27 Dec 2005    Post subject: Reply with quote
does it do it in all gears? ie when you go into 4-5 and be hard on the throttle does the bike's revs soar more than normal?
PostPosted: 12:09 - 27 Dec 2005    Post subject: Reply with quote
Is it staying in the power band when you change up at that point? Have a feeling it might just be dropping out of the power band and then not have enough power to maintain the speed.
1983 model would be an early RG without a power valve I think, so there will be a large difference between in the power and out of it.
Getting on a bit, possibly needing new pistons and a good service would make this problem worse.
rg 250 freak
PostPosted: 12:18 - 27 Dec 2005    Post subject: Reply with quote
yes it is getting on bit but it has had a rebuild it was bored out to nearly a 300 thats what the guy told me i also tried the needle adjustment to give me more fuel but it didnt help thought it also might need different jets because it has been rebored so keep going with the help
thanks Confused
rg 250 freak
PostPosted: 12:22 - 27 Dec 2005    Post subject: Reply with quote
thanks for the reply steve but the revs die down when i change into 5th but it still goes hard from 1st to 4th
oneil sg1
PostPosted: 13:29 - 27 Dec 2005    Post subject: rg ? Reply with quote
Is it a Japanese import by any chance?
PostPosted: 14:26 - 27 Dec 2005    Post subject: Reply with quote
Needle only really affects the mixture in the mid range. However running lean on a 2 stroke tends to result in rather sudden and disasterous engine problems.
sickpup
Old Timer
PostPosted: 17:02 - 27 Dec 2005    Post subject: Reply with quote
It won't need rejetting for the big bore. Does it still have its airbox?
rg 250 freak
PostPosted: 11:43 - 30 Dec 2005    Post subject: Reply with quote
yes it does still have its air box
and what i have been told that it is an import bike
but i cant tell the difference . i have been fiddling with it for a few days and have been adjusting the mixture screw out bit by bit the same on both carbs and now it takes off well .tonight i had it to 140 and still one more gear to go it seems to be running well does this mean i have done the right thing or not
oneil sg1
PostPosted: 11:47 - 30 Dec 2005    Post subject: rg? Reply with quote
If it,s an import,there,s a good chance it,s restricted to 112mph,
rg 250 freak
PostPosted: 11:59 - 30 Dec 2005    Post subject: Reply with quote
well dont stop there how can i tell or find out what do i look for and were is it ppppppppppplllllllllllllllllleeeeeeeaaaaaaaasssssssseeeeeeee
help
sickpup
Old Timer
PostPosted: 12:09 - 30 Dec 2005    Post subject: Re: rg? Reply with quote
No there isn't. Restriction didn't start till 1989.
rg 250 freak
PostPosted: 12:13 - 30 Dec 2005    Post subject: Reply with quote
thanks for the info mate have you any more info on these bikes
PostPosted: 12:15 - 30 Dec 2005    Post subject: Reply with quote
Even if it was restricted then the restrictions came in at 112mph / 180kmh, a long way after this one is flat out (although the CBR250 seems to have an anti tamper device so that if you disconnect the speedo it limits the performance even more).
The mixture screws only really affect the mixture at very limited throttle openings. The jet that mainly affects the mixture on full throttle is the main jet which cannot be adjusted, you just have to substitute larger ones in their place.
The last post was made 20 years, 69 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 81.65 Kb
