Getting fuel line off of tap
fast_tzr
PostPosted: 15:13 - 27 Dec 2005    Post subject: Getting fuel line off of tap Reply with quote
Right I need to get my tank off, however the fuel line is proving to be a bastard to get off of the tap, I'm pretty sure its not a vacuum tap, so are there any tricks to getting it off?
NC30UK
PostPosted: 15:24 - 27 Dec 2005    Post subject: Reply with quote
Hot water, if not then it is corrded on. Cut it off, clean the old bits of pipe off the tap and you'll be able to push it on again
fast_tzr
PostPosted: 15:37 - 27 Dec 2005    Post subject: Reply with quote
how do I get hot water on it?
EDIT: I'll try pouring some on it or something.
fast_tzr
PostPosted: 16:40 - 27 Dec 2005    Post subject: Reply with quote
tried that, cant really poor it from a cup, too small a space, any other ideas?
mr.z
PostPosted: 16:51 - 27 Dec 2005    Post subject: Reply with quote
It might be worth replaceing, its only like 50p per metre (nearby it is anyways)
Personally i get some pliers arround it (the part going over the pipe) and work it over and over till it loosens, then pull it off with my free hand...
At worst cut it off (but make sure you can get to halfrauds or the like)
Saint Matt
PostPosted: 17:03 - 27 Dec 2005    Post subject: Reply with quote
Have you got a funnel and a small amount of hose pipe? Put the hose pipe onto the end of the funnel and pour it through that. Should be easier that way Smile
fast_tzr
PostPosted: 17:09 - 27 Dec 2005    Post subject: Reply with quote
Sorted it now, poored it from a bottle, didnt really help, so I got a knife and made a small cut at the end of the pipe, slipped off after that. That was an okay thing to do right?(The cut is only on the bit of the pipe that goes over the tap, so none should leak)
Saint Matt
PostPosted: 17:43 - 27 Dec 2005    Post subject: Reply with quote
I'd get a new one if there is no slack in it, but if there is some slack I would cut that piece off completely, then use the rest over the tap Smile
mchaggis
PostPosted: 17:58 - 27 Dec 2005    Post subject: Reply with quote
A pair of long nosed pliers and a little WD40 does wonders. Try levering it off rather than just pulling.
I must not be a troll...
Mmmm, Guinness
The last post was made 20 years, 74 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 59.24 Kb
