Oxford hot grips.
True Blue
PostPosted: 12:53 - 29 Dec 2005    Post subject: Oxford hot grips. Reply with quote
Has anyone fitted these things before? Either to a GSXR or SV? What's the deal with the throttle grip side? The hotgrip is smooth inside but the throttle grip isn't. The only way I can see to get it on is to butcher the white plastic body on my handle bar. That can't be right, can it??? Question
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
PostPosted: 12:56 - 29 Dec 2005    Post subject: Reply with quote
You might have to cut away the bit at the end. The ridges on the throttle tube are to stop the grip turning on it, but you glue the hot grips in place anyway so that should not be a problem.
True Blue
PostPosted: 13:02 - 29 Dec 2005    Post subject: Reply with quote
I reckon I'd need to chop of both these bits...
That's a bit shitty is it not? What if I want to take them off and refit normal grips? Thumbs Down
PostPosted: 13:04 - 29 Dec 2005    Post subject: Reply with quote
Yep. However being glued in place they are unlikely to come off without doing damage anyway.
syl
PostPosted: 15:59 - 29 Dec 2005    Post subject: Reply with quote
You get to buy a new throttle tube.
Current bike: Kawasaki Z750S
xploitation
PostPosted: 16:04 - 29 Dec 2005    Post subject: Reply with quote
you can get velcrow covers that you hook up to the battry nd put a control on the tank!
Piaggio NRG MC3 "Put the headphones in, Lid on and pull away"
BIKE FUNDS-----?-600
CBT-Done THEORY-Not Booked TEST-Not Booked
planet rider
PostPosted: 16:27 - 29 Dec 2005    Post subject: Reply with quote
hi ive just fitted some on my bandit and had to cut down that ring of plastic at the front as they do not fit over it once thats done it will be a bit hard do get it over the rest of the throttle but if you hit the end of the grips with a rubber mallet(not to hard) they go on perfect oh and remember to check first how you want the wire to go as one you've got it on there there a bugger to remove ..
daz
Xj 900
The last post was made 20 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 54.41 Kb
