Problem with my 'new' bike...
jinxy88
PostPosted: 09:11 - 29 Dec 2005    Post subject: Problem with my 'new' bike... Reply with quote
Well I am the proud new owner of a RS125 that I am using to learn on before my direct access. It’s a 2000 model and not too bad condition really...
Just a couple of things I’m going to have a crack at fixing today and wondered if anyone could give me a few ideas what could be the problem:
1. The Rev counter doesn’t seem to be moving at all, the bike runs fine just the Rev counter doesn’t move, and being a first bike I need all the help I can get so this needs to be fixed!
2. The left indicator doesn’t seem to function, (hopefully this is just the bulb) but the right side seems to be blinking at an irregular pace.
Think that’s about it, Rev counter is my main worry... I have heard it is digital on my model of RS?? Any more help appreciated!
Thanks. Thumbs Up
TimC
PostPosted: 10:44 - 29 Dec 2005    Post subject: Reply with quote
not sure about the rev counter but the indicators i can help with, if one bulbs going faster than it should be it means the other bulb is blown Thumbs Up (the rev counter might just be a loose wire)
puremagic72
PostPosted: 15:26 - 29 Dec 2005    Post subject: Reply with quote
yes agree with timc, hasppened to mine a while ago about the indicators that is, changed the bulb and it was fine.
As for the rev counter, could well be loose cable, keep the bike going in neutral, and open the throttle a bit, at the same time just twiddle the rev counter cable to see if you can see it going.
All the best,
Baz. Thumbs Up
jinxy88
PostPosted: 16:58 - 29 Dec 2005    Post subject: Reply with quote
Thanks for all the help fellas, had it in pieces today and sorted the problems out:
1. The Rev counter had a load of loose wires and plugs from some previous bodge jobs I think...
2. The same with the indicators, loose cables and bad connections, cleaned them up and seems to be working fine, but do RS125 indys flash quite fast cause they seem to be flashing at quite a rate...
Anyway, job done!
Noggin
PostPosted: 21:42 - 29 Dec 2005    Post subject: Reply with quote
Are the indicators original aprilia ones or aftermarket ones?
I found that when I put aftermarket ones on my old NSR, the flash rate increased. I had to buy a new relay to sort it out.
Craig G(Noggin)
Current bike: kawasaki zx12r 2002
Track bike: yamaha r6 1998
Old Bike: honda NSR 125 1998
jinxy88
PostPosted: 22:03 - 29 Dec 2005    Post subject: Reply with quote
Yeh, they are after-market... any idea where I could get a relay that would sort this problem out??
puremagic72
PostPosted: 22:47 - 29 Dec 2005    Post subject: Reply with quote
yes def, new relay will sort this prob out my friend. only couple of pound, if you dont know where to find one, i will look for you.
Let me know,
Baz. Thumbs Up
jinxy88
PostPosted: 23:08 - 29 Dec 2005    Post subject: Reply with quote
Well I have done a little bit more research and it seems the relay I need is a 4 x 23W 2 pin relay. Going to drop by a couple of automotive shops tomorrow and see if I can pick one up and solve my problem!
puremagic72
PostPosted: 23:44 - 29 Dec 2005    Post subject: Reply with quote
the relay is under the pillion seat, the relay is 21W Uk spec.
puremagic72
PostPosted: 23:56 - 29 Dec 2005    Post subject: Reply with quote
send these an e-mail
ultimate_parts_uk@btconnect.com
The last post was made 20 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 63.22 Kb
