Footpeg position
MikeH
PostPosted: 19:21 - 30 Dec 2005    Post subject: Footpeg position Reply with quote
Just tried on my new boots and when I get on the bike, I can't change up the box Shocked
Could be a bit of an issue to say the least !! I'm going to have to modify the pegs or chop 4 inches off my feet, anyone else have this problem or am I just mutant with big size 12 flippers instead of feet Mr. Green
Busa Junkie
mchaggis
PostPosted: 19:23 - 30 Dec 2005    Post subject: Reply with quote
Try moving the gear selector a spline or two around the input shaft. That may well move the lever into a position you can shift with. The boots might be better once they're broken into as well.
I must not be a troll...
Mmmm, Guinness
MikeH
PostPosted: 19:53 - 30 Dec 2005    Post subject: Reply with quote
hmm tried that first, it's too close where it comes out across the frame to move it the way it would have to go. The only thing I can think of is to chop the peg mounts from their brackets and re weld them further back, pain in the arse of a job but can't see another way.
Busa Junkie
iDON
PostPosted: 20:04 - 30 Dec 2005    Post subject: Reply with quote
What about the shift linkage rod? Adjusting this one (with the locknuts on each end) you can alter peg position without changing the bracket on the input shaft.
www.idon-industries.com
Teaman
PostPosted: 20:16 - 30 Dec 2005    Post subject: Re: Footpeg position Reply with quote
small footed git Smile
i have size 13 feet. you should be able to wind most gear selectors up and down , failing that just alter it by taking it off and putting it back on at a slightly higher position.
you should be fine then,
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
cagiva gezzer
PostPosted: 20:23 - 30 Dec 2005    Post subject: Reply with quote
I'm assuming there's no linkage if you're talking about the KLE. Try finding a longer lever.
MikeH
PostPosted: 20:29 - 30 Dec 2005    Post subject: Reply with quote
yep, the lever on the KLE is a reversed type affair coming straight off the selector shaft so I'd need to shorten it to move it away from the peg, but then there would probably not be enough leverage which is why I was looking at moving the pegs back a couple of inch's instead.
Confused Question
Busa Junkie
kb-zxr
PostPosted: 20:42 - 30 Dec 2005    Post subject: Reply with quote
I found that I kept missing the gear shifter every now and then with new boots Embarassed
Give it a week and you'll be fine Smile
PostPosted: 20:47 - 30 Dec 2005    Post subject: Reply with quote
My mate Chris managed fine on my KLE with size 13 army pro-boots on. I manage fine with size 10 combat boots too which have a big, reinforced toecap.
Move the gear lever DOWN not up. Down a long way, the pivot is located some way below the footpeg and this will actually increase the size of the gap between the lever and the footpeg. It will seem wierd at first but allows you to shift gears when you are up on the pegs too.
MikeH
PostPosted: 20:51 - 30 Dec 2005    Post subject: Reply with quote
It won't go down any further it catches on the frame !?!? I wonder if it's the right lever or if someone swopped it ?
If I get chance I'll take a pic tomorrow, could you check it against yours ?
Busa Junkie
PostPosted: 21:13 - 30 Dec 2005    Post subject: Reply with quote
I'm going to be away for new year.
You probably can't see much on this piccy I have but I'll put it up anyway.
https://www.bikechatforums.com/download.php?id=22989
Also, this is what the manual says:
MikeH
PostPosted: 21:20 - 30 Dec 2005    Post subject: Reply with quote
That diagram is different to mine, I don't have any linkages just a lever straight off the splined selector shaft, I'm getting the feeling mines had a bodge job done on it Mad
Busa Junkie
cagiva gezzer
PostPosted: 21:23 - 30 Dec 2005    Post subject: Reply with quote
I was looking at bikepics and saw the same linkages, so i assumed they changed it for 2006 bikes. I aslso assumed you had a 2006 bike as your avatar is one. If you've got a <2005 then it's been changed.
MikeH
PostPosted: 21:24 - 30 Dec 2005    Post subject: Reply with quote
It's a '93 imported in 2002
Busa Junkie
cagiva gezzer
PostPosted: 21:26 - 30 Dec 2005    Post subject: Reply with quote
Time to get hunting for original parts then.
All the bikes on here have linkages. - https://www.bikepics.com/kawasaki/kle500/
Bendy
Mrs Sensible
PostPosted: 21:27 - 30 Dec 2005    Post subject: Reply with quote
New boots?
Break them in before you panic, I could barely change gear in mine when I first got them.
MikeH
PostPosted: 21:35 - 30 Dec 2005    Post subject: Reply with quote
Git !!!! your right just been looking through and they're all the same so mines been butchered Mad I thought it was a bit tight even before I got the boots but I can see why now.
Cheers fellas, at least I know what I'm up against now Rolling Eyes
Now to find a breaker with the bits I need
Mike Thumbs Up
P.S. Bendy I'm going to take the dog for a walk in me new kinky boots tomorrow........wonder what the neighbours will think Mr. Green
Busa Junkie
kwacky
Or buy some Gilles rearsets Wink Thumbs Up
MikeH
PostPosted: 21:43 - 30 Dec 2005    Post subject: Reply with quote
Found one on Ebay and better still it's just up the road Wink
Gilles Rearsets Question whats that then ?
Busa Junkie
Josh|RD125LC
PostPosted: 11:52 - 31 Dec 2005    Post subject: Reply with quote
Bit OT, but is the KLE a paralell twin?
Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures
kwacky
PostPosted: 12:02 - 31 Dec 2005    Post subject: Reply with quote
Gilles rearsets? They are fully adjustable rearsets for sportsbikes. Nice bit of bling.
From their website:
A radical departure from traditional styling, the Gilles Rearsets present an aggressive, muscular appearance. Beyond the aesthetics, the Gilles Rearsets are a completely thought out technical apparatus. Start with all-aluminum construction and CNC machining, add micro-adjustability, and finish with even the smallest details covered (like the toe pegs: the brake side is knurled for positive grip, while the shift side is smooth to enable the boot to move above or below as necessary).
Of course, all parts are available individually, and most parts are interchangeable with stock components. Weight savings over stock rearsets can reach up to two pounds! Gilles rearsets are the perfect complement to a custom street bike and the perfect accessory for a championship chasing race bike.
* Titanium - CNC machined from aircraft spec alloy
* Fully adjustable for each machine
* Carbon heel plates included
* Precision bearing mounted lever arms
* O/E brake light switch retained
* All linkages / bolts / hose extensions included
* TUV / ISO 9002 approved
* All spare components parts available (with individual part numbers)
* Full fitting instructions included
MikeH
PostPosted: 12:37 - 31 Dec 2005    Post subject: Reply with quote
Yep Cool
Busa Junkie
Nath
PostPosted: 13:39 - 31 Dec 2005    Post subject: Reply with quote
Just another daft tarty thing to piss away all your money on Rolling Eyes
Hard livin', hard luck.
kwacky
PostPosted: 14:25 - 31 Dec 2005    Post subject: Reply with quote
Improved ground clearance
Fully adjustable so you can set them for specific use i.e lower for distance higher for track
Greater comfort
Stronger than many OE rearsets
Easy to source
Can replace specific parts rather than the whole unit as most manufacturers insist
Smoother gear changes
I take it you've not tried any?
syl
PostPosted: 15:08 - 31 Dec 2005    Post subject: Re: Footpeg position Reply with quote
I felt just the same when I bought some proper boots - thought I was never going to be able to change up as my foot would bearly squeeze into the gap between peg and lever. A couple of weeks on and I wonder what I was worried about.
Don't change anything hastily.
Current bike: Kawasaki Z750S
The last post was made 20 years, 296 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 129.35 Kb
