Chain Adjustment
iCraig
PostPosted: 17:38 - 30 Dec 2005    Post subject: Chain Adjustment Reply with quote
Right with it being the festive season and being off work, I decided to do some maintainence on the CB.
I have adjusted the chain, and am wondering if people think its too tight.
I have got a video of the free play.
Click Here for the video
Also I decided once and for all to sort the rear mudguard out which was holier than swiss cheese, and I couldn't get a new one from Honda UK as they are out of production with the bike being over 10 years old and David Silvers could get a new one for £70 from Honda Brazil (whom originally made the bike) but it'd have taken 3 months to get atleast so they quoted.
So I decided to use some Glass Fibre Metal repair stuff and this is how it turned out:
https://www.gsxf.co.uk/mudguard.JPG
It doesn't look half bad, and hopefully it'll stop the frame rails corroding, which is eventually what happens after the mudguard has corroded as it lets the water in (In Honda's wisdom they used a metal mudguard under the rear wheel, geniuses aren't they!).
Its paint black now and looks OK, can't be arsed sanding it and filling it like I should not like people see it is it! Laughing
Teaman
PostPosted: 18:18 - 30 Dec 2005    Post subject: Reply with quote
your vid is a bit dark,
best bet is sit on your bike and have someone check the tension,
id say about 1-2cm either way,
check to see if the spockets are looking like shark fins another way is to dig out the manual from the manuals thread and check exactly.
just make sure you have still got the wheel inline with the front
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
iCraig
PostPosted: 00:38 - 31 Dec 2005    Post subject: Reply with quote
I'd say there is about 1-1.3cms of play in the chain.
Just wondering if thats too little, cos I don't wanna damage the gearbox.
Teaman
PostPosted: 16:02 - 31 Dec 2005    Post subject: Reply with quote
its not the gearbox you damage, you stress the chain more if its too tight, the cush drive in your rear wheel takes up most of teh hammer,
if your chains too slack it will be jerky and again stress the chain,,
if it feels wrong whilst riding, setting off and everything id say slacken it off a bit,
get some fat arse to sit on the bike and check the tention, this is basicly the sme s riding over a speed bump,
i have a feeling you should be ok
syl
PostPosted: 19:22 - 31 Dec 2005    Post subject: Re: Chain Adjustment Reply with quote
How often do you have to adjust the chain? I just took my bike (Kawasaki Z750S) in for its first (500 mile) service and the engineer said the chain could do with a little more looking after (lubing and adjusting). What does he want, blood?
I've lubed it almost every time I've ridden it (including the night before the service). I admit I haven't adjusted the chain - although I hadn't expected to have to, prior to the first 500 mile service (when he could do it for me in the unlikely event that it was necessary).
Current bike: Kawasaki Z750S
Teaman
PostPosted: 19:52 - 31 Dec 2005    Post subject: Reply with quote
er well erm
the mechanics a tosser with nowt else better to say, its a first service, what dya expect .
ok so here somes the checks and when
question, how often do you wash your bike?
if every week there you go,, check tyres, tyre preasure., break wear, chain tension and lubeness Smile
and pretty much all you can check,, safety wise.,,.
Kram
PostPosted: 00:40 - 03 Jan 2006    Post subject: Reply with quote
i give the chain a kick once a week, to check the tension. Give it a lube.
i have had my chain about 6000 miles, and adjusted it about 4-5 times. there pretty strong, and can't really go wrong with them
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
The last post was made 20 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 54.62 Kb
