is this battery charger any good?
izzi81
PostPosted: 14:42 - 01 Jan 2006    Post subject: is this battery charger any good? Reply with quote
Spotted it in the Argos sale catalogue, looks like a pretty good price for a battery charger! It says it's ok for motorbike but I was wondering what the knowledgeable opinion of you lot was before I went and bought one (plus if it is a good deal other might be able to make use of it too!)
https://www.argos.co.uk/webapp/wcs/stores/servlet/Search?storeId=10001&catalogId=3801&langId=-1&searchTerms=7506899&go.x=6&go.y=18
"The problem with the French is they have no word for 'entrepreneur' " George W Bush
Age doesn't matter unless you're a cheese
https://www.bikepics.com/members/izzi81
riichy
PostPosted: 14:48 - 01 Jan 2006    Post subject: Reply with quote
thats looks ok.... bike and cars most run on 12V so will be ok for a bike.....
look around at other shops might get a better deal.. cheap is not always best Thumbs Up Karma
.......... PLOD ............ zx636 2004
stryker
PostPosted: 15:03 - 01 Jan 2006    Post subject: Reply with quote
The only dif I can see is something like an optimate will try and condition a battery where as the argos one will not.
No biggy tho.
Now what?
sickpup
Old Timer
PostPosted: 18:06 - 01 Jan 2006    Post subject: Reply with quote
11amp charge rate is to high for a bike battery.
True Blue
PostPosted: 21:03 - 01 Jan 2006    Post subject: Reply with quote
That'll only be if the battery is deeply discharged. It says "Automatic change to maintenance charge"
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
sickpup
Old Timer
PostPosted: 21:47 - 01 Jan 2006    Post subject: Reply with quote
Which is still about 10X to high for a bike battery.
izzi81
PostPosted: 02:50 - 02 Jan 2006    Post subject: Reply with quote
I was all set to buy one... but now I'm not so sure? Is 11amp going to fry my battery or something?
mr.z
PostPosted: 03:06 - 02 Jan 2006    Post subject: Reply with quote
https://www.vehicle-wiring-products.co.uk/VWPweb2000/soldering/soldering.html
Last item
https://www.vehicle-wiring-products.co.uk/VWPweb2000/soldering/Images/bch3pin.GIF
Chargeing the battery too fast wont do the battery any good, afaik its because it can boil off the electrollite (may be wrong) or at least shoten the lifespan of the battery, not to mention giveing off much more hydrogen gas in the process, so be very carefull taking teminals on/off (it can expode and isn't something you want happening)
I think 6amp is more like what you'd use on a bike?
Anyone looking at an optimate, RING make a charger now that does all the same, but its £40, its allot bigger but it would only be a problem if you planned takeing it on holliday or something Thinking
sickpup
Old Timer
PostPosted: 03:31 - 02 Jan 2006    Post subject: Reply with quote
Well a lot of bikes such as blades, CBR600 etc use a YTX9-BS battery which should be charged at 0.9amps. Unless you have a real big battery that charger is gonna boil your battery dry.
True Blue
PostPosted: 12:20 - 02 Jan 2006    Post subject: Reply with quote
Oops, I read that as 1.1 Amps. Embarassed Yeah that's way too high. Especially if you have a gel filled battery. If you do, it is more important to have a controlled charge rate. These batteries don't spill and do not produce as much corrosive gas, so is unlikely to explode or anything, but if you don't charge it properly it'll die pretty qiuck.
garymv
PostPosted: 12:52 - 02 Jan 2006    Post subject: just.... Reply with quote
just buy one of these
https://cgi.ebay.co.uk/Optimate-III-Battery-Charger-new_W0QQitemZ8024644066QQcategoryZ25643QQrdZ1QQcmdZViewItem
You can sure of these.
izzi81
PostPosted: 13:02 - 02 Jan 2006    Post subject: Reply with quote
ok, definitely not battery charger from Argos for me! Thanks guys Smile
sickpup
Old Timer
PostPosted: 17:10 - 02 Jan 2006    Post subject: Reply with quote
No 6 amp is to high.
True Blue
PostPosted: 12:44 - 03 Jan 2006    Post subject: Reply with quote
This one is probably better for you... https://www.jsaccessories.co.uk/hermes/shop/item?itemId=1514
The last post was made 20 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.8 - MySQL Queries: 13 - Page Size: 82.43 Kb
