Piston slap
Josh|RD125LC
PostPosted: 23:27 - 01 Jan 2006    Post subject: Piston slap Reply with quote
What on earth is it? I posted a quick vid of my bike engine running on the RD forum concerning a knocking that can be heard. Its not affecting the bike in any way that I know of, but just sounds more knocky than it used to. I was told it sounded a bit slappy, so Im assuming that person was reffering to piston slap. What is it and is it bad?
Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures
Josh|RD125LC
PostPosted: 23:29 - 01 Jan 2006    Post subject: Reply with quote
Heres the link to the video:
https://www.zippyvideos.com/2576067882949196/mov000011
RD125LC Pictures
PostPosted: 23:51 - 01 Jan 2006    Post subject: Reply with quote
No sound when I looked at the video.
Piston slap would indicate a worn bore and / or piston (or a rubbish rebore job). Fairly easy and cheap to sort on an iron bored 2 stroke.
mchaggis
PostPosted: 02:04 - 02 Jan 2006    Post subject: Reply with quote
Piston slap, often when there is too much clearance between the piston skirt and the cylinder wall, normally the result of excessive wear or some clown putting a piston a size too small in. Laughing The main problem is the explosion pushing the piston downwards; the piston doesn't go straight down, but is whanged into into the side by the force of the explosion.
The RD is a twin, isn't it? By shorting out one plug at a time, you can see if the knocking sound changes. It won't eliminate everything, but it'll unload the piston without the explosion (which would normally be pushing the piston into the side of the cylinder). If the slapping isn't there when that cylinder isn't sparking, you can probably rule out anything to do with the bottom end or any ancilliaries. That is assuming it'll run on one cylinder.
The piston normally needs replacing and the cylinder reboring/ honing to smooth it out and get the clearance right. If the cylinder has warped into an oval (unlikely really though), it could end up needing to be scrapped if the walls are too thin to bore it circular again.
I must not be a troll...
Mmmm, Guinness
Josh|RD125LC
PostPosted: 11:10 - 02 Jan 2006    Post subject: Reply with quote
I could hone it but that means fitting a larger piston?
RD125LC Pictures
PostPosted: 12:11 - 02 Jan 2006    Post subject: Reply with quote
Yep, would need a new piston of the right size and either a hone or (more likely) a rebore, if it is piston slap.
Josh|RD125LC
PostPosted: 22:58 - 02 Jan 2006    Post subject: Reply with quote
Hmm. Sounds like more money spending on the damn thing. At times I wonder whether its worth it.
If it is slapping, will it do any damage? Because I don't fancy fixing it at this present moment.
RD125LC Pictures
Jamie.
PostPosted: 23:07 - 02 Jan 2006    Post subject: Reply with quote
the link is dead now, is it possible you could host it again so i can hear it? as i was told today my bike may have piston slap too, alough mine sounds more like a tapping noise
PostPosted: 23:14 - 02 Jan 2006    Post subject: Reply with quote
Well, ultimatly it could cause major damage to the piston, skirt cracking off and dropping into the engine.
Not likely though.
Think RD pistons are cheap and a rebore should not be more than £20. Gentle few hours work.
Josh|RD125LC
PostPosted: 23:25 - 02 Jan 2006    Post subject: Reply with quote
Heres a new link to the vid for Jamie.
https://www.zippyvideos.com/1105661262993186/mov000011/
RD125LC Pictures
Jamie.
PostPosted: 23:31 - 02 Jan 2006    Post subject: Reply with quote
ahh yes, mine sounds the exactly the same as that , alough your knocking noise is slightly louder than mine
Josh|RD125LC
PostPosted: 21:02 - 05 Jan 2006    Post subject: Reply with quote
Just been thinking, but when the engine was apart, I checked the clutch basket, and it had quite deep wear marks where the plates have been wearing away at the sides. I filed out these wear marks and used the basket again. Now Im just wondering whether the knocking Im hearing is the clutch plates rattling, as there is bound to be a tad more play where I have filed away at the basket, bigger gap so they have a bit more play in and rattling?
If its not that, then its most likely piston slap, and I don;t know what to do, Im putting the bike up for sale once I have a car and have sold my 50 so I want to get it sorted really!
RD125LC Pictures
The last post was made 20 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 76.74 Kb
