| Josh|RD125LC |
 Josh|RD125LC World Chat Champion
 Posted: 23:27 - 01 Jan 2006 Post subject: Piston slap |
What on earth is it? I posted a quick vid of my bike engine running on the RD forum concerning a knocking that can be heard. Its not affecting the bike in any way that I know of, but just sounds more knocky than it used to. I was told it sounded a bit slappy, so Im assuming that person was reffering to piston slap. What is it and is it bad? ____________________ Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures |
| Josh|RD125LC |
| Kickstart |
 Kickstart The Oracle
| mchaggis |
 mchaggis World Chat Champion
 Posted: 02:04 - 02 Jan 2006 Post subject: |
Piston slap, often when there is too much clearance between the piston skirt and the cylinder wall, normally the result of excessive wear or some clown putting a piston a size too small in. The main problem is the explosion pushing the piston downwards; the piston doesn't go straight down, but is whanged into into the side by the force of the explosion.
The RD is a twin, isn't it? By shorting out one plug at a time, you can see if the knocking sound changes. It won't eliminate everything, but it'll unload the piston without the explosion (which would normally be pushing the piston into the side of the cylinder). If the slapping isn't there when that cylinder isn't sparking, you can probably rule out anything to do with the bottom end or any ancilliaries. That is assuming it'll run on one cylinder.
The piston normally needs replacing and the cylinder reboring/ honing to smooth it out and get the clearance right. If the cylinder has warped into an oval (unlikely really though), it could end up needing to be scrapped if the walls are too thin to bore it circular again. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| Josh|RD125LC |
 Posted: 11:10 - 02 Jan 2006 Post subject: |
I could hone it but that means fitting a larger piston? ____________________ Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures |
| Kickstart |
| Josh|RD125LC |
 Posted: 22:58 - 02 Jan 2006 Post subject: |
Hmm. Sounds like more money spending on the damn thing. At times I wonder whether its worth it.
If it is slapping, will it do any damage? Because I don't fancy fixing it at this present moment. ____________________ Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures |
| Jamie. |
 Jamie. World Chat Champion
| Kickstart |
| Josh|RD125LC |
| Jamie. |
| Josh|RD125LC |
 Posted: 21:02 - 05 Jan 2006 Post subject: |
Just been thinking, but when the engine was apart, I checked the clutch basket, and it had quite deep wear marks where the plates have been wearing away at the sides. I filed out these wear marks and used the basket again. Now Im just wondering whether the knocking Im hearing is the clutch plates rattling, as there is bound to be a tad more play where I have filed away at the basket, bigger gap so they have a bit more play in and rattling?
If its not that, then its most likely piston slap, and I don;t know what to do, Im putting the bike up for sale once I have a car and have sold my 50 so I want to get it sorted really! ____________________ Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures |
The last post was made 20 years, 63 days ago. Instead of replying here, would creating a new thread be more useful? |
