I am sorry for this thread...
Whosthedaddy
PostPosted: 10:58 - 03 Jan 2006    Post subject: I am sorry for this thread... Reply with quote
I was unable to start my bike after it dramatically cut out one morning at 70mph Shocked
Was unable to jump start (old battery was 'dead'), so bought new battery today.
Engine turns Thumbs Up
Nothing else Thumbs Down
Thought might be weak battery as brand new off the shelf..........jumped it...............still nothing Crying or Very sad
Could this be a spark problem? According to the manaul, to check the plugs:
remove the side pannels
remove air ducts
disconnect fuel tap
remove tank Exclamation
This is well beyond my skills and capabilities to do.
I am worried I will have to get bike towed to a garage to be fixed. But, this is what a kwak garage said when I emailed them before christmas when I thought it may be the altenator (which I still haven't ruled out yet):
"Our best advise to you is to try and get your money back from the seller as the machine is not easily fixable and will probably end up costing you more than it is worth"
Would a mobile mechanic be any good?
Sorry for this flat battery / not starting question again, and again and agin.....thanks for all the help on previous occasions
Am tempted to get out a very large hammer...........you've been warned bike Evil or Very Mad
camcam
PostPosted: 11:30 - 03 Jan 2006    Post subject: Reply with quote
have you checked the killswitch
laugh now cry later
SUZUKI GSXR600 98 SRAD RED/BLACK ***sold gonna miss you***
SUZUKI GSXR750 '00 K1 SHAPE BLUE/WHITE
sickpup
Old Timer
PostPosted: 11:37 - 03 Jan 2006    Post subject: Reply with quote
Add me to MSN and lets have a little chat.
Address in my profile.
Whosthedaddy
PostPosted: 11:39 - 03 Jan 2006    Post subject: Reply with quote
Kill switch 'off'
Engine makes 'turn over' noises' but nothing else.
Bike has been on side stand for 3 weeks or so, put fuel protection in when last filled up with petrol to prevent the jets becoming 'gumed' up.
I have got 3/4 tank of petrol before anyone asks
judderman3000
PostPosted: 12:53 - 03 Jan 2006    Post subject: Reply with quote
I had a similar problem with my bike, try the spark plugs, shouldnt be too hard, if they are sparking then it might be the ignition coil is too weak to spark under pressure as i found with mine, shouldnt be expensive to pick a new one up, what bike is it? have you found that the engine idle has started going fast recently (2stroke)
If you have got a spark warm the plugs, pour a little petrol down the hole where you got the plugs bang it back in an give it a whirl. You should be able to find your problem quite easily if you know what you are looking for.
Judd - Hornet 600 (restricted) Micron Can, Belly Pan, Custom rear end, Single seat cowl, need to sort front end out e.g. headlights and USD forks...
carvell
Scuttler
PostPosted: 13:10 - 03 Jan 2006    Post subject: Reply with quote
If it's been left then the carbs might be full of gunk, and just need taking apart and putting back together.
Whosthedaddy wrote:
Kill switch 'off'
Eh?
Yamaha TDM 850
Whosthedaddy
PostPosted: 13:27 - 03 Jan 2006    Post subject: Reply with quote
Sorry James, just wrote you a (long) email and deleted it instead of sending Mad
Summoned up the courage to start to strip the bike down, easier than the manual states Confused Unfortunately, its pissing it down and I got fed up with getting wet Rain
One quick question, if I haven't asked enough. Is this the only line that I need to disconnect and clamp from the fuel tap?
The tank is 3/4 full, what position should the tap be in as I dont want my feet to be washed in gushing petrol Confused
Whosthedaddy
PostPosted: 13:30 - 03 Jan 2006    Post subject: Reply with quote
Whosthedaddy wrote:
Kill switch 'off'
Eh?[/quote]
ie not 'on'
sickpup
Old Timer
PostPosted: 15:17 - 03 Jan 2006    Post subject: Reply with quote
Pretty sure you don't need to disconnect the fuel lines. Pull the tank backwards and turn it 90 degrees, rest it on the frame rails.
Finglonga
PostPosted: 15:54 - 03 Jan 2006    Post subject: Reply with quote
Has it got a side stand switch that may be stuck/Fecked?
Andy Sez....
F.Y.Y.F.F.
Guest
PostPosted: 17:33 - 03 Jan 2006    Post subject: Re: I am sorry for this thread... Reply with quote
'dramatically' like someone turned the key off, or did it sputter a bit first like you're out of petrol?
If it just clicked off that sounds like a leccy problem, check the stand switch as suggested.
Your gas won't have gone off this quickly.
Whosthedaddy
PostPosted: 18:28 - 03 Jan 2006    Post subject: Reply with quote
As far as Im aware, it doesn't have a stand cut off switch, have tried both up and down, clutch in out. Tried starting in gear (clutch in) and bike lurches forward Confused
Thanks for tip about turning tank Thumbs Up
The power was lost after a couple of backfires at speed, top gear, lights on. When parked in lay-by, the parking lights, oil and neutral lights still worked Question
The turn over with the new battery sounded good, just needed the 'vroom vroom' with the twist of the trottle Twisted Evil
Jamie.
PostPosted: 18:56 - 03 Jan 2006    Post subject: Reply with quote
try disconnecting the killswitch completly
Guest
PostPosted: 19:54 - 03 Jan 2006    Post subject: Reply with quote
https://img.photobucket.com/albums/v471/fastfitter/P1010043.jpg
Wossat?
Brava210
PostPosted: 20:14 - 03 Jan 2006    Post subject: Reply with quote
take it from an AA Patrol first check for spark at plug,if no spark then work your way back through the system i.e coil-cdi- switches feeds etc.do the same for the fuel system start at the end and work your way back. You will need a multi-meter and a circuit tester,dont use a bulb lit circuit tester,use an led type,as a bulb lit tester could damage delicate components.I hope i am not being patronising but simply pulling random switches and things apart is a very long winded method !! Very Happy Very Happy
Gary ps (i know some people do not like -AA,RAC etc,just trying to help...)
Honda Novio, Puch Grand Prix, Suzuki AP50, CZ 125, Wassell 125, Montesa 348,Honda 125TDC, Suzuki 100ER, Suzuki GSF650 Bandit, Aprillia Pegaso, Honda PCX125, Honda Forza300, BMW G310 GS, Suzuki SFV650, Honda CB500X
CHARLEY SAYS " ALWAYS TELL YOUR MUMMY BEFORE YOU GO OFF SOMEWHERE"
Whosthedaddy
PostPosted: 21:28 - 03 Jan 2006    Post subject: Reply with quote
No problem Thumbs Up
goatblower
PostPosted: 22:10 - 03 Jan 2006    Post subject: Reply with quote
I've had a lost spark problem recently on a 10 year old motocross bike with basic CDI ignition system - nearly set about it with a very large hammer!
Checked the electrical components as per manual and found some of the circuit resistances apparently out of spec. Whilst poking around the connections with my multimeter I found that the push on wiring connectors had unexpected resistance. In desperation I soldered all the connections and lo and behold a nice fat spark!
Such a small amount of power generated by a kick over that it needs all it can get.
Might be no help with your problem of course but worth checking if you don't have a spark
Whosthedaddy
PostPosted: 17:30 - 04 Jan 2006    Post subject: Reply with quote
Its alive!
Moved the tank backwards exposing a very attractive engine Laughing
Realised that I couldn't remove the spark plugs with the socket used for a car (too big), firmly placed HT leads back. I then tried to start the engine, thought what the hell...............it farted.
With quick haste, the tank was secured again.........turned the key..........fart.................nothing.................fart and started Thumbs Up
Didn't actually do anything as far as I'm aware Thinking
Sped round the block a few times to make sure the battery put in yesterday has something to go on
I feel that reliability will be an issue Confused Thinking of riding bike tonight to work...............hmmmmm............feck it, yes!
Thanks for everyones suggestions and helpfulness
harry69koi
PostPosted: 18:00 - 04 Jan 2006    Post subject: Reply with quote
Sounds like you had a kink in the tank vacuum hose Idea moving the tank may have removed the offending kink? just a thought,Lee
FJ1200 The ultimate tourer Smile
Whosthedaddy
PostPosted: 01:23 - 05 Jan 2006    Post subject: Reply with quote
Short lived celebrations Evil or Very Mad
Bike was doing so well cruising along. Then just passed where the same thing happened a couple of weeks ago..............dial lights went out.........down shifted to go down slip road...............backfires and farts.................all power gone....................indicator lights not flashing on dash (remians constant orange)....................lights very dim...............engine wont turn over Exclamation
Yet again, my bike is at the side of a road and at the mercy of those bastard gypos Middle Finger
Hopefully I will be able to jump it in the morning, or push (yes up hill) to a motorcycle garage about 800 yards away for diagnosis.
I think its something electrical Question
Watch ebay for it 'spares or repair, any offers'
bish777
PostPosted: 10:34 - 05 Jan 2006    Post subject: Reply with quote
hmmmmm,
check all the connections that are visible and ensure the battery terminals are screwed down.
get it in the dry and let the thing dry out- water may have got in.
Then spray EVERY part of the loom in ignition sealer to prevent shorting out.
Also you may need a new ignition switch possibly?
GSXR1100J
Finglonga
PostPosted: 15:54 - 05 Jan 2006    Post subject: Reply with quote
As Bish sez! sounds like a mother of a bad earth. Crying or Very sad
Andy Sez....
F.Y.Y.F.F.
pipnet11
PostPosted: 17:04 - 05 Jan 2006    Post subject: Reply with quote
Sounds like your battery's not getting charged properly to me. Could be a huge number of reasons why not mind.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
Whosthedaddy
PostPosted: 17:07 - 05 Jan 2006    Post subject: Reply with quote
Almost killed me pushing the bike. Got bruises all over legs from foot pegs!
Its in the hands of the mechanics now, just waiting for that phone call to say 'are you sitting down.............heres the bill'
yaut
PostPosted: 18:41 - 14 Jan 2006    Post subject: Reply with quote
and... how much how much is it?
all dogs go to heaven
The last post was made 20 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.26 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 133.84 Kb
