| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 10:58 - 03 Jan 2006 Post subject: I am sorry for this thread... |
I was unable to start my bike after it dramatically cut out one morning at 70mph
Was unable to jump start (old battery was 'dead'), so bought new battery today.
Engine turns
Nothing else
Thought might be weak battery as brand new off the shelf..........jumped it...............still nothing
Could this be a spark problem? According to the manaul, to check the plugs:
remove the side pannels
remove air ducts
disconnect fuel tap
remove tank
This is well beyond my skills and capabilities to do.
I am worried I will have to get bike towed to a garage to be fixed. But, this is what a kwak garage said when I emailed them before christmas when I thought it may be the altenator (which I still haven't ruled out yet):
"Our best advise to you is to try and get your money back from the seller as the machine is not easily fixable and will probably end up costing you more than it is worth"
Would a mobile mechanic be any good?
Sorry for this flat battery / not starting question again, and again and agin.....thanks for all the help on previous occasions
Am tempted to get out a very large hammer...........you've been warned bike  ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| camcam |
 camcam Trackday Trickster
| sickpup |
 sickpup Old Timer
| Whosthedaddy |
 Posted: 11:39 - 03 Jan 2006 Post subject: |
Kill switch 'off'
Engine makes 'turn over' noises' but nothing else.
Bike has been on side stand for 3 weeks or so, put fuel protection in when last filled up with petrol to prevent the jets becoming 'gumed' up.
I have got 3/4 tank of petrol before anyone asks ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| judderman3000 |
 judderman3000 Nova Slayer
 Posted: 12:53 - 03 Jan 2006 Post subject: |
I had a similar problem with my bike, try the spark plugs, shouldnt be too hard, if they are sparking then it might be the ignition coil is too weak to spark under pressure as i found with mine, shouldnt be expensive to pick a new one up, what bike is it? have you found that the engine idle has started going fast recently (2stroke)
If you have got a spark warm the plugs, pour a little petrol down the hole where you got the plugs bang it back in an give it a whirl. You should be able to find your problem quite easily if you know what you are looking for. ____________________ Judd - Hornet 600 (restricted) Micron Can, Belly Pan, Custom rear end, Single seat cowl, need to sort front end out e.g. headlights and USD forks... |
| carvell |
 carvell Scuttler
| Whosthedaddy |
 Posted: 13:27 - 03 Jan 2006 Post subject: |
Sorry James, just wrote you a (long) email and deleted it instead of sending
Summoned up the courage to start to strip the bike down, easier than the manual states Unfortunately, its pissing it down and I got fed up with getting wet
One quick question, if I haven't asked enough. Is this the only line that I need to disconnect and clamp from the fuel tap?
The tank is 3/4 full, what position should the tap be in as I dont want my feet to be washed in gushing petrol  ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| Whosthedaddy |
| sickpup |
 sickpup Old Timer
| Finglonga |
 Finglonga World Chat Champion
| Guest |
 Guest Brolly Dolly
| Whosthedaddy |
 Posted: 18:28 - 03 Jan 2006 Post subject: |
As far as Im aware, it doesn't have a stand cut off switch, have tried both up and down, clutch in out. Tried starting in gear (clutch in) and bike lurches forward
Thanks for tip about turning tank
The power was lost after a couple of backfires at speed, top gear, lights on. When parked in lay-by, the parking lights, oil and neutral lights still worked
The turn over with the new battery sounded good, just needed the 'vroom vroom' with the twist of the trottle  ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| Jamie. |
 Jamie. World Chat Champion
| Guest |
 Guest Brolly Dolly
| Brava210 |
 Brava210 Crazy Courier
 Posted: 20:14 - 03 Jan 2006 Post subject: |
take it from an AA Patrol first check for spark at plug,if no spark then work your way back through the system i.e coil-cdi- switches feeds etc.do the same for the fuel system start at the end and work your way back. You will need a multi-meter and a circuit tester,dont use a bulb lit circuit tester,use an led type,as a bulb lit tester could damage delicate components.I hope i am not being patronising but simply pulling random switches and things apart is a very long winded method !!
Gary ps (i know some people do not like -AA,RAC etc,just trying to help...) ____________________ Honda Novio, Puch Grand Prix, Suzuki AP50, CZ 125, Wassell 125, Montesa 348,Honda 125TDC, Suzuki 100ER, Suzuki GSF650 Bandit, Aprillia Pegaso, Honda PCX125, Honda Forza300, BMW G310 GS, Suzuki SFV650, Honda CB500X
CHARLEY SAYS " ALWAYS TELL YOUR MUMMY BEFORE YOU GO OFF SOMEWHERE" |
| Whosthedaddy |
 Posted: 21:28 - 03 Jan 2006 Post subject: |
No problem  ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| goatblower |
 goatblower Two Stroke Sniffer
| Whosthedaddy |
 Posted: 17:30 - 04 Jan 2006 Post subject: |
Its alive!
Moved the tank backwards exposing a very attractive engine
Realised that I couldn't remove the spark plugs with the socket used for a car (too big), firmly placed HT leads back. I then tried to start the engine, thought what the hell...............it farted.
With quick haste, the tank was secured again.........turned the key..........fart.................nothing.................fart and started
Didn't actually do anything as far as I'm aware
Sped round the block a few times to make sure the battery put in yesterday has something to go on
I feel that reliability will be an issue Thinking of riding bike tonight to work...............hmmmmm............feck it, yes!
Thanks for everyones suggestions and helpfulness ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| harry69koi |
 harry69koi Renault 5 Driver
 Posted: 18:00 - 04 Jan 2006 Post subject: |
Sounds like you had a kink in the tank vacuum hose moving the tank may have removed the offending kink? just a thought,Lee ____________________ FJ1200 The ultimate tourer  |
| Whosthedaddy |
 Posted: 01:23 - 05 Jan 2006 Post subject: |
Short lived celebrations
Bike was doing so well cruising along. Then just passed where the same thing happened a couple of weeks ago..............dial lights went out.........down shifted to go down slip road...............backfires and farts.................all power gone....................indicator lights not flashing on dash (remians constant orange)....................lights very dim...............engine wont turn over
Yet again, my bike is at the side of a road and at the mercy of those bastard gypos
Hopefully I will be able to jump it in the morning, or push (yes up hill) to a motorcycle garage about 800 yards away for diagnosis.
I think its something electrical
Watch ebay for it 'spares or repair, any offers' ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| bish777 |
 bish777 World Chat Champion
| Finglonga |
 Posted: 15:54 - 05 Jan 2006 Post subject: |
As Bish sez! sounds like a mother of a bad earth.  ____________________ Andy Sez....
F.Y.Y.F.F. |
| pipnet11 |
 pipnet11 Brolly Dolly
| Whosthedaddy |
 Posted: 17:07 - 05 Jan 2006 Post subject: |
Almost killed me pushing the bike. Got bruises all over legs from foot pegs!
Its in the hands of the mechanics now, just waiting for that phone call to say 'are you sitting down.............heres the bill' ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| yaut |
 yaut Derestricted Danger
The last post was made 20 years, 42 days ago. Instead of replying here, would creating a new thread be more useful? |
