how long do i run in for?
hazza
PostPosted: 14:49 - 03 Jan 2006    Post subject: how long do i run in for? Reply with quote
i have put new crank seals, piston and rings in my rxs 100....how long should it be run in for?
Guest
PostPosted: 17:27 - 03 Jan 2006    Post subject: Reply with quote
Take it steady for about 300 miles, I'd up the oil pump ratio a little as well but it's not vital if you go steady.
Jamie.
PostPosted: 18:49 - 03 Jan 2006    Post subject: Reply with quote
ive heard its helpfull to add some 2-stroke oil into the tank, so you have the extra lubrication for the run-in period
alains
PostPosted: 19:32 - 03 Jan 2006    Post subject: Reply with quote
i denied that , it's helpfull to add oil only when you have some air in the oil pipe in case of direct oil injection , otherwise it will more carbon in you cyl head & exhaust
hazza
PostPosted: 19:41 - 03 Jan 2006    Post subject: Reply with quote
hoow careful should i be????....whats the maximum i should work it?
alains
PostPosted: 19:54 - 03 Jan 2006    Post subject: Reply with quote
normally 50% of your red zone , the time is function of what you have changed in your top engine
hazza
PostPosted: 19:58 - 03 Jan 2006    Post subject: Reply with quote
so 50 mph in top aint gonna hurt it?...does it do any damage if i accelarate hard>?
alains
PostPosted: 20:06 - 03 Jan 2006    Post subject: Reply with quote
the risk is to break piston or rings even the barrel or the crank
if the max speed of this bike is 70 mph the red zone should be at 60 and your running in must be around 30 mph
hazza
PostPosted: 17:24 - 04 Jan 2006    Post subject: Reply with quote
only 30mph????
bidman
PostPosted: 17:48 - 04 Jan 2006    Post subject: Reply with quote
only 30mph????
If you want to get the most out of your bike in the long run, yes. You should fully bed in the new kit before even attempting to give it any abuse, that includes accelerating hard. Thumbs Up
Dan
Don't ride it, RAG IT!!
hazza
PostPosted: 18:44 - 04 Jan 2006    Post subject: Reply with quote
its gona be a long 300 miles then lol...o well if its better for the bike...i mean i dont wana have to strip it down again in a few months
alains
PostPosted: 19:09 - 04 Jan 2006    Post subject: Reply with quote
you can do that progressively
first 100 miles 30 mph
next 100 35 mph
last 100 40 mph
and for 2 or 3 seconds no problem if you go 5 mph more
Jamie.
PostPosted: 00:26 - 05 Jan 2006    Post subject: Reply with quote
its also a good idea to not ride your bike and let it idle at low revvs for say 30-45mins with the ocassional slight pull of the throttle, as the first couple of hours is the most vital
mchaggis
PostPosted: 01:21 - 05 Jan 2006    Post subject: Reply with quote
You sure?
The rings need to be worked to bed in to the bore properly. Running it for extended periods without putting it under any load will tend to just run the rings up and down the bore without doing much other than glazing the surface and overheating.
By all means do make sure it is warmed up properly before you start, but I wouldn't leave it idling for too long.
I must not be a troll...
Mmmm, Guinness
sickpup
Old Timer
PostPosted: 11:16 - 05 Jan 2006    Post subject: Reply with quote
I'd ride it normally myself. As Mchaggis points out you do need to stress the rings to get them to seat.
PostPosted: 13:59 - 05 Jan 2006    Post subject: Reply with quote
I pretty much ride normally, just slower and not using the higher revs. Vary the throttle, do not leave it just idling (about the worst thing you can do) and do not strain it (eg, don't try going up hill in top with the engine shuddering). Revs wise I use half the red line as a guideline.
The last post was made 20 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 86.58 Kb
