PHBH28 Carb on a NS125R?
clemsta
PostPosted: 20:03 - 03 Jan 2006    Post subject: PHBH28 Carb on a NS125R? Reply with quote
The Honda NS125R runs a PHBH 26mm carb as standard, i have added a allspeed full system and a k&N. The NSR125 runs a PHBH 28mm carb, if i was to put the 28mm carb onto the NS would it blow the rings or would it just run better.
Thanks
Adam
SOMEONE CALL THE DOCTOR! I've got 2 stroke fever!!!
OGRI - Stuff everything, i've always got my bike!
DAS Passed - 7/6/06
Jack_Cheese
PostPosted: 20:38 - 03 Jan 2006    Post subject: Reply with quote
It may help, a larger carb is normally required when a larger exhaust and better filter are fitted. Have you not changed the jetting yet? Fit the larger carb, and then jet it to suit, i'm sure it won't hurt. Worst it can do is make your bike a bit rich, at which point just refit the 26mm Dell orto, then bung a large jet in it.
I'm sure there's at least a handfull of people on here who can help you with specifice, but my only advice to you is suck it and see...
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
mrchips
PostPosted: 20:49 - 03 Jan 2006    Post subject: Reply with quote
If its set up for the 28 I dont see a problem.
Northern Irish? www.nibikers.com
cagiva gezzer
PostPosted: 21:26 - 03 Jan 2006    Post subject: Reply with quote
I'd go for the 32 or 34mm versions if i was after a power increase.
PostPosted: 21:27 - 03 Jan 2006    Post subject: Reply with quote
Might well help, but might well take a while to get the jetting acceptable.
The last post was made 20 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 44.24 Kb
