| jonnay |
 jonnay World Chat Champion
 Posted: 17:45 - 03 Jan 2006 Post subject: Blipping the throttle |
Hi,
Is there any need to blip the throttle on a 2t bike? I've recently found my back end sliding around when I'm downshifting from speed, and although it's not *too* dangerous (the slides only last a second or so), I'd still like to avoid it incase it happens on a corner, and to preserve my tyre, as well!
There's not much engine braking on a 2 stroke, and theres just about enough to lock the wheel, so would blipping the throttle help it at all? I don't really know how to do it either, so I'd just like to know whether it makes a noticeable difference before I go about asking mates how to do it.
A worthwhile skill to learn, or a waste of time?
Cheers,
Jon ____________________ ::'04 Yamaha Jog:: || ::'01 Honda NSR:: || ::'00 Suzuki Swift:: || ::'89 Swift GTi:: || ::'96 Swift Poverty Spec:: || ::'92 Swift GTi:: |
| stinkwheel |
 Posted: 17:55 - 03 Jan 2006 Post subject: |
Blipping the throttle helps to give a smooth change. If you are locking the wheel on a small capacity 2-smoke, I would say you are changing down way too soon.
You could lock the rear on my 660cc 4-stroke single by downshifting but you had to be taking the piss with the gearshifting or so hard on the brakes the wheel was barely touching the ground ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Wave2k |
 Wave2k G's Stalker
| loply |
 loply World Chat Champion
 Posted: 18:02 - 03 Jan 2006 Post subject: |
Evidently has enough to lock the wheel, wave... ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| loply |
 Posted: 18:05 - 03 Jan 2006 Post subject: |
Sorry, to answer your question, blipping the throttle most certainly would prevent your from locking the wheel in the way you have been.
You do of course need to learn to do it smoothly, blipping too little will result in engine braking and too much is also dangerous as it can launch you into a corner faster than you mean to. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| Finglonga |
 Finglonga World Chat Champion
 Posted: 18:07 - 03 Jan 2006 Post subject: |
Blipping saves the gearbox greaf when changing down as it gets the engine and road speed synchronized and stops the crunch as you change down......or it should if you do it properly.  ____________________ Andy Sez....
F.Y.Y.F.F. |
| jonnay |
 Posted: 18:12 - 03 Jan 2006 Post subject: |
OK, cheers people, I'll set about trying to get to grips with it
Stinkwheel, yeh, it only happens if I bang through the box very quickly in the dry, but in the wet it was a bit more severe. I also had a tyre on there which was rather expired, and I imagine that didn't help matters. I'll see if it still does it with my new tyre now it's fitted
Thanks!
| NC30UK |
 NC30UK Scooby Slapper
| stinkwheel |
| Method |
 Method World Chat Champion
 Posted: 18:53 - 03 Jan 2006 Post subject: |
I was thinking about this the other day...
I dont do it myself, but thought i would try it and couldnt...
So would someone care to explain how you blip the throttle to downshift - Properly.
 ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado
My Bikepics.com - No Brakes, No Gears... No Fear. |
| SoND |
 SoND World Chat Champion
 Posted: 18:54 - 03 Jan 2006 Post subject: |
On the topic of engine braking...
Does engine braking do your motor any harm because it just doesnt sound healthy to me? ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
| Milo |
 Milo World Chat Champion
| Wave2k |
 Wave2k G's Stalker
| satans_BIG_helper |
 satans_BIG_helper Nearly there...
| Zimbo |
 Zimbo World Chat Champion
 Posted: 19:38 - 03 Jan 2006 Post subject: |
As suggested above, leave it in the higher gear till the revs have dropped a lot more, then change down.
I used to do the same thing, on a trackday last year i was braking from speed into a hairpin and skating the back wheel as i did so every lap, with accompanying screching of rear tyre.
After a few sessions, whilst waiting to go out, the marshal advised me to change down later to prevent this.
"Oh" said I, "i don't mind the back sliding under braking, doesn't bother me"
"well" sid he, "it's certainly bothering us . . . "
So i took his advice, and found I was no slower by leaving the downshift till later, the slides stopped, and I was more controlled into the bend. Lesson learned. |
| riichy |
 riichy World Chat Champion
 Posted: 20:47 - 03 Jan 2006 Post subject: |
i just do it becouse, its sounds good ....
and makes it smooth too, i would say go for it blipp all you like cant do not harm  ____________________ .......... PLOD ............ zx636 2004 |
| JonB |
 JonB Afraid of Mileage
 Posted: 21:11 - 03 Jan 2006 Post subject: |
Ever since the trackday I have blipped the throttle everytime I change down after a scary moment changing down into a corner.  ____________________ Be careful whose advice you buy, but, be patient with those who supply it. Advice is a form of nostalgia, dispensing it is a way of fishing the past from the disposal, wiping it off, painting over the ugly parts and recycling it for more than it?s worth. |
| Kickstart |
 Kickstart The Oracle
 Posted: 21:36 - 03 Jan 2006 Post subject: |
| Milo |
 Posted: 21:40 - 03 Jan 2006 Post subject: |
At first I started it because I'd heard it was good, I kept doing it because it sounded cool and I keep doing it because it's so much smoother to downshift and now totally natural to do.  ____________________ Shaft drives rule.  |
| EllioTT_GiXXeR |
 EllioTT_GiXXeR Could Be A Chat Bot
| Milo |
| stinkwheel |
| NC30UK |
| colin1 |
 colin1 Captain Safety
| EllioTT_GiXXeR |
The last post was made 20 years, 70 days ago. Instead of replying here, would creating a new thread be more useful? |
