New to BCF and need help
burdo
PostPosted: 15:01 - 07 Jan 2006    Post subject: New to BCF and need help Reply with quote
Hello im new here signed up to see if anyone could help me with problem with my NSR 125 RV model
I would greatly apreciate any help any one can give.
We think it is a ignition problem, everything was fine then just riding along it just cut out.
we have had it apart and noticed that we can get it running then the spark just goes.
We think maby , pulse genorator or cdi unit.
Any ideas into my mistery would be so much apriciated.
PostPosted: 15:51 - 07 Jan 2006    Post subject: Reply with quote
I would give it a new plug and charge the battery first off. then work backwards from there checking everything as you go.
Plug cap: Tight fit, good state or repair, not full of water.
HT lead: No cracks, attached firmly at both ends.
Ignition coil: Good frame earth, terminals firmly attached, getting hot? Test the windings with a multimeter. (Coils can sometimes 'break down' as they get hot.). If you can, borrow one off someone else and try it in.
CDI unit: Tricky to test. Make sure all the connectors are corrosion free and making good contact. Easiest way to test it is to try another one on as you need either an expensive or very old fashioned (non electronic) meter to test the circuits.
Pulse coil: I would have thought this would either work, or not work. I did once have a bike where it came loose and wasn't close enough to pick up the signal, you would be able to see this. You can check the windings with a multimeter.
mchaggis
PostPosted: 16:46 - 07 Jan 2006    Post subject: Reply with quote
Make sure you check and eliminate the simple problems first, electrical connections, flat batteries and fouled plugs being most of those.
I was plagued for months with a misfire on my 125, and went through all sorts of rigamaroles trying to work out what it could be. By chance when it failed to spark all together, I noticed that a connector to the CDI which appeared to be connected, wasn't. I crimped it back on, and bob's your uncle, problem solved.
I must not be a troll...
Mmmm, Guinness
burdo
PostPosted: 02:48 - 11 Jan 2006    Post subject: Thanks Reply with quote
hi havent been on for a while just up graded to a 160 gb barracuda and 1 gig ram. Anyway
Thanks for the infor and the help i have a day off tomorrow and will try everythink you told me and post back.
As to the multi meter we have all the tools and equipt ment needed due to our trade.
Thanks again guys will keep u posted on my wee nsr
alains
PostPosted: 11:37 - 11 Jan 2006    Post subject: Reply with quote
download my file https://www.geneva-racing.com/~alains/NSRtips.doc and look about ignition bug . also check the CDI's connectors , especially the 4 wires which hold a black/yellow wire . this wire is the CDI discharge in the coil (and also your tacho feed)
The last post was made 20 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 44.23 Kb
