dtr 125 (milky coloured oil)
lee125
PostPosted: 21:13 - 07 Jan 2006    Post subject: dtr 125 (milky coloured oil) Reply with quote
hi today i went out on my dtr 125 and after it had been running a while checked the oil cause it used to have a leak but fixed it and filled it up again but when i checked how much oil was in it was like a milky white colour so i havnt run it since and i just want to know if anyone has any idea what could have caused this
Guest
PostPosted: 21:16 - 07 Jan 2006    Post subject: Reply with quote
Usually a sign of condensation if the bike's not been run often or just used for short journeys. A good long run (20 miles ish) to get it nice and warm will cure it.
Unless the bike is watercooled, then it could be a sign that water is getting into the oil but on a (I'm guessing) 2 stroke it'd be very rare for the water to get into the gearbox oil.
Jamie.
im not sure, but milky colour oil is what you want, if its black then needs replaced
lee125
PostPosted: 21:33 - 07 Jan 2006    Post subject: Reply with quote
yes it is watercooled
Bezzer
PostPosted: 23:00 - 07 Jan 2006    Post subject: Reply with quote
As Guest says it's probably just condensation "gloop" from the oil due to it not reaching working temperature much in these cold conditions. Just to make sure check your coolant level and also your oil level, if you haven't lost coolant or gained oil then it's OK.
Only way to get rid is to give it a decent run fairly regularly and perhaps block your rad off a bit so it warms up quicker.
craigT19
Jolly Green Giant
PostPosted: 00:01 - 09 Jan 2006    Post subject: Reply with quote
the guest is correct. condensation builds up in the dt125's air injection system in the exhaust, gets sucked up into the airbox and goes down the crank case breather, then mixes with the oil, giving u your milky colour, good run will solve it.
head gasket shouldt be a problem being an open engine you will see the leak.
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
sickpup
Old Timer
PostPosted: 05:21 - 09 Jan 2006    Post subject: Reply with quote
craigT19 wrote:
Head gasket shouldn't be a problem being an open engine you will see the leak.
Please explain?
craigT19
Jolly Green Giant
PostPosted: 22:38 - 09 Jan 2006    Post subject: Reply with quote
erm well the head gasket is the thing that seals the head, to the bore.
if the gasket had failed u would see signs of leakage, be it an area of darker metle as if it were geting hotter than the metal around it, or in some caser an oil or coolant leak
Finglonga
PostPosted: 22:52 - 09 Jan 2006    Post subject: Reply with quote
Google 'Emulsification'. Wink
Andy Sez....
F.Y.Y.F.F.
sickpup
Old Timer
PostPosted: 23:43 - 09 Jan 2006    Post subject: Reply with quote
On a water cooled bike the head will (generally) go between a bore (high pressure) and a water passage (lower pressure) NOT between a water passage and the outside world. The head would have to be either loose or warped to see coolant coming out of the gap between head and barrel. The outer metal of the head or barrel would not normally have any difference in colour regardless of a blown headgasket.
craigT19
Jolly Green Giant
PostPosted: 03:44 - 10 Jan 2006    Post subject: Reply with quote
i was giving info based on my own recent expeirience of an aerox 50 (water cooled) pissing coolant all over my bench because the head gasket was brocken when the owner decided to fit his own bore kit.
coolant is pumped at lower pressure than the oil j
yes, but its still belting round at a fairly high pressure, certanly high enuf to find an exit Laughing, ive see coolant leaking from the head on a tdm 850 and an fjr1300 all within the last 6 months, neither had a damaged or warped head.
Knowlsey
PostPosted: 04:16 - 10 Jan 2006    Post subject: Reply with quote
you will probably know if its a head gasket leakage if it gets in the oil, simply by draining the oil and seeing how much is in there and how watery white it is and it would overheat due to a watered down oil and many other things happen with bikes as apposed to cars
The last post was made 20 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 72.57 Kb
