| lee125 |
 lee125 World Chat Champion
| Guest |
 Guest Brolly Dolly
| Jamie. |
 Jamie. World Chat Champion
| lee125 |
| Bezzer |
 Bezzer World Chat Champion
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 00:01 - 09 Jan 2006 Post subject: |
the guest is correct. condensation builds up in the dt125's air injection system in the exhaust, gets sucked up into the airbox and goes down the crank case breather, then mixes with the oil, giving u your milky colour, good run will solve it.
head gasket shouldt be a problem being an open engine you will see the leak. ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
| sickpup |
 sickpup Old Timer
| craigT19 |
 Posted: 22:38 - 09 Jan 2006 Post subject: |
erm well the head gasket is the thing that seals the head, to the bore.
if the gasket had failed u would see signs of leakage, be it an area of darker metle as if it were geting hotter than the metal around it, or in some caser an oil or coolant leak ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| Finglonga |
 Finglonga World Chat Champion
 Posted: 22:52 - 09 Jan 2006 Post subject: |
Google 'Emulsification'.  ____________________ Andy Sez....
F.Y.Y.F.F. |
| sickpup |
 sickpup Old Timer
| craigT19 |
 Posted: 03:44 - 10 Jan 2006 Post subject: |
i was giving info based on my own recent expeirience of an aerox 50 (water cooled) pissing coolant all over my bench because the head gasket was brocken when the owner decided to fit his own bore kit.
coolant is pumped at lower pressure than the oil j
yes, but its still belting round at a fairly high pressure, certanly high enuf to find an exit , ive see coolant leaking from the head on a tdm 850 and an fjr1300 all within the last 6 months, neither had a damaged or warped head. ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| Knowlsey |
 Knowlsey Scooby Slapper
The last post was made 20 years, 167 days ago. Instead of replying here, would creating a new thread be more useful? |
