URGENT - Help a forum member (yokogeri)
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3, 4  Next
PostPosted: 00:21 - 09 Jan 2006    Post subject: Reply with quote
The only time my bike ever gets a wash (admittedly not that often) it is with a jet washer. Never had a problem other than drum brakes not working for a bit after.
PostPosted: 00:24 - 09 Jan 2006    Post subject: Reply with quote
Jet washed the bikes regularly without any problems as well.
For Yokos bike, how long is the fuel pump running for on start up? If it clicks for 5 seconds then turns off, and does the same on the next time the ignition is switched on then it is not pumping any fuel.
Nath
PostPosted: 00:32 - 09 Jan 2006    Post subject: Reply with quote
You said his bike wouldn't start after stopping at a set of traffic lights. Did the bike cut out of its own accord, or did he stall it (maybe because the engine was cold and wouldn't idle).
If the bike didn't cut out, a mate with a car and some jump leads would come in handy - Sometimes bikes can just be funny about not starting, and the only solution is to keep cranking them over till they give in. A can of easystart or equivalent tends to help as well.
Hard livin', hard luck.
BenBray
PostPosted: 01:53 - 09 Jan 2006    Post subject: Reply with quote
Dude that sucks - a girl at work had a similar situation with her bike.
Her dad reckoned it was a damp thing I was told today - but it sounds exactly the same, except for her bike would catch for a moment then completely die.
Atleast you're sleeping in a nice warm place, and you're not in the middle of nowhere with no signal on your mobile, a fucked bike and the pissing rain.
Take it easy dude
Ben
Current Bike: nc30
PostPosted: 01:54 - 09 Jan 2006    Post subject: Reply with quote
It started up ok warmed up. Got to the end of the road. pulled out a junction and it just died. Press the started and it turns the engine but nothing happens. Put the choke on and try again and it ALMOST catches but not enough to start it.
Sound to me like you have flooded the engine, possibly after stalling through icing up. In a car you need to pull the fuse for the fuel pump, turn the engine over 'till it catches then quickly stick the fuse back in. Should work with a bike too (used to happen on my Jawa quite a lot in the winter, you had to switch the fuel off, open the throttle wide and kick it over 'till it fired up)
It should fire up no problem in the morning if I am right.
McJamweasel
BCF Junkie
PostPosted: 11:13 - 09 Jan 2006    Post subject: Reply with quote
If you bought it from a dealer then you will have a warrantyw ith it, so unless it's something consumable thats gone you won't have to pay a penny.
BCF: Be yourself, just don't be an arse.
EDBANGER
PostPosted: 11:16 - 09 Jan 2006    Post subject: Reply with quote
I had the same problem on my Bandit 400 all the time, with all that jerking aswell. Really did my head in. Having it serviced seemed to clear it up for quite a while, definately a carb problem.
If you can't spot the sucker in your first half hour at the table, you are the sucker.
dainesefreak
PostPosted: 11:18 - 09 Jan 2006    Post subject: Reply with quote
Try cleaning the sidestand, make sure there's no shit around the top. I've heard of the kill switch not working properly when it's dirty, not sure if it powers the starter motor or not though with this fault though.
Davo
Davo To The Rescue!
PostPosted: 11:44 - 09 Jan 2006    Post subject: Reply with quote
My R6 won't turn over if the sidestand is down and the bike is in gear.
I suspect its either a fueling or a ignition system issue.
Yoko, like I said get that new can off it first just incase they try and say that it's the cause.
Nath
PostPosted: 11:48 - 09 Jan 2006    Post subject: Reply with quote
In that case I would agree with Stinkwheel in that doesn't want to start because you flooded the engine.
Before calling a breakdown company, I would make an effort to find a car to jump it off. You will look like a right pillock if you call for a breakdown truck because you flooded your engine.
Bendy
Mrs Sensible
PostPosted: 11:51 - 09 Jan 2006    Post subject: Reply with quote
He bought an exhaust from the Garage of Doom... the rot is spreading. Laughing
Davo
Davo To The Rescue!
PostPosted: 11:54 - 09 Jan 2006    Post subject: Reply with quote
Yokogeri, best not come to Brands Hatch
Wave2k
G's Stalker
PostPosted: 13:58 - 09 Jan 2006    Post subject: Reply with quote
lol he rang me at 10pm when i was in a deep sleep and i turned my phone off.
I know that if fuel isnt going to the engine, the pump or whatever ticks VERY loud, or it did on my cbr.
Ducati 1299 Panigale
2009 Corvette C6 z51
Alastair
PostPosted: 14:43 - 09 Jan 2006    Post subject: Reply with quote
Bad luck Scott, seems you're a bit unlucky with bikes if the one I bought off you is anything to go by Wink
Isn't it under warranty though? Thought you bought it from a garage?
Alastair
PostPosted: 14:50 - 09 Jan 2006    Post subject: Reply with quote
Yokogeri wrote:
So damn annoying had the bike 3 weeks and it breaks down
*shakes head in disgust*
I know that feeling, only had mine 1 week before it blew Sad
Bec
PostPosted: 17:17 - 09 Jan 2006    Post subject: Re: URGENT - Help a forum member (yokogeri) Reply with quote
White Noise wrote:
Hi all
on his way back from his sheep shagging trip in wales.
There is no proof that Welsh shag sheep !!!
Bec
PostPosted: 17:38 - 09 Jan 2006    Post subject: Reply with quote
He's ginger so he must be an Irish ! Not Welsh ! So HAAAAAAAA.
Wave2k
G's Stalker
PostPosted: 19:13 - 09 Jan 2006    Post subject: Reply with quote
Scottish
Bec
PostPosted: 19:16 - 09 Jan 2006    Post subject: Reply with quote
Yeah Irish people are ginger to!!
tatters
Exxon Valdez
PostPosted: 19:18 - 09 Jan 2006    Post subject: Reply with quote
Yokogeri Laughing
Bec
PostPosted: 19:29 - 09 Jan 2006    Post subject: Reply with quote
Why do Welsh people always get the pi$$ taken out of them! I never see any English people being the punch line in jokes!
White Noise
Mr Dudwee
PostPosted: 19:45 - 09 Jan 2006    Post subject: Reply with quote
because the welsh, scots and irish just hate us enough anyway and don't need to succome to jokes
WN
Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight
Wave2k
G's Stalker
PostPosted: 19:55 - 09 Jan 2006    Post subject: Reply with quote
his welsh roots come out.
tatters
Exxon Valdez
PostPosted: 20:01 - 09 Jan 2006    Post subject: Reply with quote
Because like most country,s on this planet we,ve kicked there arse and therefore have the right to take the piss. Laughing
"What shore does not know our blood"
Wave2k
G's Stalker
PostPosted: 20:10 - 09 Jan 2006    Post subject: Reply with quote
because every country in the UK is a bitch to england, and have all been pwned.
The last post was made 20 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 130.16 Kb
