KLE500 tuning to GPZ500 specifications
PostPosted: 19:56 - 10 Jan 2006    Post subject: KLE500 tuning to GPZ500 specifications Reply with quote
Right. There are at least ten equines lurking somewhere inside my KLE engine. The bore, stroke, compression ratio and valve diameter are the same as the GPZ. The KLE has 50 ponies, the GPZ has 60 ponies as standard. This leaves only a few places for them to hide.
I have a spare GPZ engine, it would be rude not to try Mr. Green
I know the carbs are different, got a pair of GPZ ones.
I reckon the cam profile is different (if only by the differing power delivery between the two engines). I checked the manual and have a procedure for changing out the cams without removing the head and camchain.
This leaves what?
Exhaust? Got that covered, there are nae baffles in the one I have.
Filter? Both have a foam element filter.
Airbox? The KLE one is massive.
Ignition timing? Thinking Not so sure about the ignition timing/mapping. The IC Igniter has the same number of wires but in different colours/orders. I can make a 'crossover' block to make them land up in the same place without butchering the loom. I wonder if this is all or if the ignition is mechanically advanced on the GPZ too?
Any thoughts? Anything I missed?
(This will be by way of a 'do it sometime when it is lighter and I am bored' type project.)
extreme3d
PostPosted: 21:48 - 10 Jan 2006    Post subject: Reply with quote
If the GPZ has more power per stroke then it stands to reason that the counter balance required would also be more so make sure they are the same to.
PostPosted: 23:11 - 10 Jan 2006    Post subject: Reply with quote
Would not surprise me if the ignition timing is different. Use shorter HT leads so the sparks do not have to travel as far, to advance the timing Laughing Wink .
Wonder if you could rig up a video camera and a timing light to check what the timing is doing as you rev the engine.
MikeH
PostPosted: 23:21 - 10 Jan 2006    Post subject: Re: KLE500 tuning to GPZ500 specifications Reply with quote
Thats being a little optimistic official figure is more like 46PS / 44BHP for the KLE, I have read that some of the european models were restricted on the intake.
I've also read about a chap that got 55 horses with just a filter, zorst and a stage 3 dynojet but then you read allsorts on t'internet Wink
Out of interest what does your top out at ?
Mike
Busa Junkie
PostPosted: 13:06 - 11 Jan 2006    Post subject: Re: KLE500 tuning to GPZ500 specifications Reply with quote
Mike
Not really sure with the new gearing, I don't have a speedo. I would guess 115/120.
sickpup
Old Timer
PostPosted: 13:39 - 11 Jan 2006    Post subject: Reply with quote
Why?
The counter balance only cancels the effect of 2 pistons moving.
map
Mr Calendar
PostPosted: 13:41 - 11 Jan 2006    Post subject: Re: KLE500 tuning to GPZ500 specifications Reply with quote
stinkwheel wrote:
...ten equines lurking somewhere inside my KLE engine...Anything I missed?...
Make sure it's painted red Very Happy
Absolute law of physics that anything red must be travelling faster Wink
veeeffarr
PostPosted: 13:48 - 11 Jan 2006    Post subject: Reply with quote
Tell that to my CG please.
MikeH
PostPosted: 13:56 - 11 Jan 2006    Post subject: Re: KLE500 tuning to GPZ500 specifications Reply with quote
stinkwheel wrote:
Mike
OK mine sees about 110 but then I've only tested it briefly hopefully after next week I'll be able to go out and test it officially Wink
Busa Junkie
extreme3d
PostPosted: 14:56 - 11 Jan 2006    Post subject: Reply with quote
sickpup wrote:
Why?
Every force in one direction has an equal force in the opposite direction. So surely the counter balance is not just to cancel the effect of the pistons moving? Granted it's primarily there to help mask the 'rocking couple' effect along the crankshaft, but a lot of thought must have gone into the size of that weight to take into account an engines performance, optimum rpm related to the gearing etc...
Which brings me onto another thought... is the gearing (the actual gearbox) on the KLE the same as the GPZ?
PostPosted: 16:09 - 11 Jan 2006    Post subject: Reply with quote
Irrespective of other factors in the design, the amount of power / torque depends on how far open the throttle is, and the balance weights do not change in mass as you open and close the throttle.
feef
Energiser Bunny
PostPosted: 17:17 - 11 Jan 2006    Post subject: Reply with quote
extreme3d wrote:
sickpup wrote:
the counter balance only cancels the effect of 2 pistons moving.
the counterbalance it there to counter the effects of the mass moving. it doesn't matter how much force was applied to the mass, it's still the same amount of mass, and the counterbalance will be moved with the same increased force (transmitted via the con-rod).
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
The last post was made 20 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 79.79 Kb
