 Posted: 19:56 - 10 Jan 2006 Post subject: KLE500 tuning to GPZ500 specifications |
Right. There are at least ten equines lurking somewhere inside my KLE engine. The bore, stroke, compression ratio and valve diameter are the same as the GPZ. The KLE has 50 ponies, the GPZ has 60 ponies as standard. This leaves only a few places for them to hide.
I have a spare GPZ engine, it would be rude not to try
I know the carbs are different, got a pair of GPZ ones.
I reckon the cam profile is different (if only by the differing power delivery between the two engines). I checked the manual and have a procedure for changing out the cams without removing the head and camchain.
This leaves what?
Exhaust? Got that covered, there are nae baffles in the one I have.
Filter? Both have a foam element filter.
Airbox? The KLE one is massive.
Ignition timing? Not so sure about the ignition timing/mapping. The IC Igniter has the same number of wires but in different colours/orders. I can make a 'crossover' block to make them land up in the same place without butchering the loom. I wonder if this is all or if the ignition is mechanically advanced on the GPZ too?
Any thoughts? Anything I missed?
(This will be by way of a 'do it sometime when it is lighter and I am bored' type project.) ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| extreme3d |
 extreme3d World Chat Champion
| MikeH |
 MikeH Brolly Dolly
| sickpup |
 sickpup Old Timer
| map |
 map Mr Calendar
 Posted: 13:41 - 11 Jan 2006 Post subject: Re: KLE500 tuning to GPZ500 specifications |
| veeeffarr |
 veeeffarr Super Spammer
| MikeH |
 MikeH Brolly Dolly
| extreme3d |
| feef |
 feef Energiser Bunny
The last post was made 20 years, 162 days ago. Instead of replying here, would creating a new thread be more useful? |
