NS125F Carb Question
Dillingsuk
PostPosted: 19:39 - 14 Jan 2006    Post subject: NS125F Carb Question Reply with quote
Just got hold of a NS125F that needs more than a little work! It hasn't got a carb. I believe its supposed to be a Dellorto 26mm? Can anyone confirm this and also does the NSR carry the same carb? Sorry can't confirm age yet as havent recieved the V5 (no number plate Mad !)
PostPosted: 19:55 - 14 Jan 2006    Post subject: Reply with quote
Should be a Dellorto PHBH26 carb, which is not the same as that used in the NSR (NSR used a 28mm carb).
Dillingsuk
PostPosted: 18:37 - 15 Jan 2006    Post subject: Reply with quote
Can I just get hold of any PHBH26? Or will some be jetted differently?
PostPosted: 19:16 - 15 Jan 2006    Post subject: Reply with quote
Ones for other bikes will be jetted differently, and there will be other differences as well (such as which jets are actually in place, where the 2 stroke oil pipe connects, etc).
To be honest, in the UK the NS is probably the most common bike fitted with that carb.
Type_Mo
PostPosted: 19:51 - 15 Jan 2006    Post subject: Reply with quote
if a 28 will fit you can get a new one here... https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4603857483&rd=1&sspagename=STRK%3AMEBI%3AIT&rd=1
and jets here aswell... https://ve-uk.com/demo/index.php?listing=2&make=MAIN+JETS&model=DELLORTO+%2B+SPACO+MAIN+JETS&group=CARB+MAIN+JETS
Good Luck
Dillingsuk
PostPosted: 22:02 - 15 Jan 2006    Post subject: Reply with quote
A Dt 125? Thats an expensive carb (£501)!?? How much work is it to get it running with a 28mm carb? NSR carb say?
fuzz
PostPosted: 22:38 - 15 Jan 2006    Post subject: Reply with quote
Type_Mo wrote:
Err, think that's the wrong link. Razz
Type_Mo wrote:
That's all good and well, but you need to know the dellorto part number for your particular carb. For PHBH, these are 6413.xxx, 1486.xx and 11600.xx for main, idle and power respectively. Just change the x's for the jet size.
Try this: https://ve-uk.com/demo/index.php?listing=2&make=COMPLETE+CARBS&model=DELLORTO&group=COMPLETE+CARBS
Or even better, https://www.dellorto.co.uk will give you a quote and you can get the exact parts you need. They are very helpful.
Type_Mo
PostPosted: 22:42 - 15 Jan 2006    Post subject: Reply with quote
oops sorri about the wrong link Laughing Laughing Laughing Doh! Doh! Brick Wall
fuzz
PostPosted: 22:51 - 15 Jan 2006    Post subject: Reply with quote
So the size of the carb (26mm, 28mm etc) is down to the choke size? What's that about? Confused
Dillingsuk
PostPosted: 18:33 - 17 Jan 2006    Post subject: Reply with quote
Choke size? I thought is was the aperature of the carb inlet?
The last post was made 20 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 66.9 Kb
