Is this Normal??
JonB_5
PostPosted: 09:25 - 16 Jan 2006    Post subject: Is this Normal?? Reply with quote
I have fitted a Carbon Can Company exhaust to my Bandit, and when I ease off after revving it high in any gear, there is a burbling sound, is this normal??
Thanks
Jon
LustyLew
PostPosted: 10:35 - 16 Jan 2006    Post subject: Reply with quote
I had a viper can on my bandit when I bought it. Used to do the same thing. Not quite sure what the reason behind it is though.
I took my can off and replaced it with the legal one when I started commuting into London.
tribal_tiger
PostPosted: 12:03 - 16 Jan 2006    Post subject: Reply with quote
Hell my CG clone does this with a standard system, though only since one of the bolts fell off Confused
I think it's something to do with unburnt fuel hitting something hot and burning off somewhere, oh bugger it, i can't remember, somone else will tell you!
How much wood would a woodchuck chuck if a woodchuck could Chuck Norris?
All of it.
Wave2k
G's Stalker
PostPosted: 12:46 - 16 Jan 2006    Post subject: Reply with quote
its running slightly rich i think, shouldnt be nothing to worry about though.
Ducati 1299 Panigale
2009 Corvette C6 z51
Method
PostPosted: 13:07 - 16 Jan 2006    Post subject: Reply with quote
My GS500 does it on a standard can and system.
Its just because your running a little richer than normal (as wave said).
Personally i love the sound, its pretty cool!
Well, its better than the backfiring i used to get because it was running seriously rich Wink
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Raffles_Gentleman Thug
I have an oval carbon can company one on my GSX-R600, and it burbles quite nicely
"Is sir addressing me or is he masticating on a house brick? Because either way sir loses his teeth."
veeeffarr
PostPosted: 13:09 - 16 Jan 2006    Post subject: Reply with quote
Let me get this straight...
Rich = Too much fuel
Lean = Too much air
Correct?
Method
PostPosted: 13:13 - 16 Jan 2006    Post subject: Reply with quote
Lean = Too much air
Correct?
Sir Yes Sir
Method
PostPosted: 13:15 - 16 Jan 2006    Post subject: Reply with quote
Well Basically.
But to be precise
Lean = Weaker Fuel to Air Ratio - Caused by too much air making its way into the combustion chamber compared to the amount of fuel
Rich = Stronger Fuel to Air Ratio - Caused by too much fuel making its way into the combustion chamber compared to the amount of air
RealNinja
Yup thats the one
It's known as overrun (I think) and is quite normal, plus in the dark you will get flames from the end of the can Wink
You will become my force of retribution. Where you tread, doom will follow. Go now and claim your destiny
Method
PostPosted: 13:16 - 16 Jan 2006    Post subject: Reply with quote
I think the ideal Air to Fuel ratio is something like
14.7 : 1 (Petrol Engine)
Its been a while since i did this with Volkswagen, so yeah Laughing
Lost_Prophet
PostPosted: 13:47 - 16 Jan 2006    Post subject: Reply with quote
just a bit over overun (as said above) nowt to worry about
Its not how fast you ride, its how you ride fast
mchaggis
PostPosted: 13:57 - 16 Jan 2006    Post subject: Reply with quote
The stoichiometric ratio for petrol is 14.7, so for every kg of petrol you'll need 14.7 kg of air. Most engines are set up to run slightly lean, so as to reduce pollution (an abundance of oxygen improves the chances that most/all of the petrol will get burnt). Since the advent of fuel injection and catalytic converters, the aim is to get it as close to the stoichiometric ratio as possible, but still allowing enough oxygen down the exhaust for the oxidation catalyst to work (it needs oxygen to burn the CO and unburnt hydrocarbons). The reduction catalyst reduces the NO back into molecular nitrogen.
Catalytic converters have to be hot to work. Don't take a cold car to an MOT or there's a good chance it'll fail on emissions.
I must not be a troll...
Mmmm, Guinness
Method
PostPosted: 14:02 - 16 Jan 2006    Post subject: Reply with quote
Thumbs Up Thats the word i was looking for, man i remember the fun we had trying to remember that at college Laughing
ash g
PostPosted: 15:34 - 16 Jan 2006    Post subject: Reply with quote
sure it's not the same sound a super bike makes when using engine braking?
the blue ninja (it's perfectly legal till your caught)
The last post was made 20 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 88.38 Kb
