Getting off a difficult nut
Gazdaman
I did a trackday!!!
PostPosted: 16:21 - 16 Jan 2006    Post subject: Getting off a difficult nut Reply with quote
Ok, I'm trying to get the fork tops off my MZ. It's not so much getting enough force behind it, I can probably do that.
But as it's a fork top it's not completely horizontal, it's on a slight angle.
The forks move, and I can't really put as much force behind it as I want to because the bike moves.
Any ideas? Put the bike on its side and use its own weight to help?
Other than that I'm going to roll the bike down to a local car shop and see if they can do it.
Gaz
Minty
PostPosted: 16:42 - 16 Jan 2006    Post subject: Reply with quote
I have had the same problem in the past. I put the steering lock on and sat on the bike - presto Very Happy
Gazdaman
I did a trackday!!!
PostPosted: 16:54 - 16 Jan 2006    Post subject: Reply with quote
Not a bad shout. MZ's don't have steering locks though. And the bike has no seat. And I don't think I'd be able to get enough force behind it from sitting on the bike. Maybe if I got a mate to sit on it.
Gaz
18_stuart_88
PostPosted: 16:57 - 16 Jan 2006    Post subject: Reply with quote
Have you got a paddock stand? If you put ithe back tire up and force it behind a wall.
Only thing i can come up with. Confused Smile
Stu Thumbs Up
Make: Honda NSR 125 R Year: 2004 Colour: Black And Silver - Died on December 18th 2005, Layed to rest December 30th 2005 :(Make: Aprilia RS 125 Year: 2000 Colour: Black And Red - Derestricted Smile Sold!
Make: Suzuki GSXR 600 SRAD Year: 1998 Colour: Red - White - Blue Mr. Green
Pic of My New Bike!!
PostPosted: 17:20 - 16 Jan 2006    Post subject: Reply with quote
Grip the front wheel between your knees as you do it?
Guest
PostPosted: 17:21 - 16 Jan 2006    Post subject: Reply with quote
Dunno the MZ exactly, but can you loosen off the top yoke pinch bolt if fitted - it might be gripping the tube just enough to snag the frok cap.
as said, full lock, correct size socket and tap it round by hand.
Gazdaman
I did a trackday!!!
PostPosted: 17:27 - 16 Jan 2006    Post subject: Reply with quote
Yeah I've had the front wheel between my knees putting the paddock stand against the wall is a good idea.
(It doesn't have a stand at all)
I have been using a ring spanner though rather than a socket. I shall go and get a socket now.
Gaz
Gazdaman
I did a trackday!!!
PostPosted: 18:02 - 16 Jan 2006    Post subject: Reply with quote
Just found out the weakest link in my new set-up is my ratchet.
My sockets now go roundy roundy roundy.
Got my new socket, put it on the nut, attached the ratchet, put my ETZ 251 exhaust on the ratchet for some extra leverage. *CRACK* oh goody, I thought, the nut's let go, nope. Ratchet broke.
Never mind, new ratchet tomorrow.
Gaz
Finglonga
PostPosted: 18:08 - 16 Jan 2006    Post subject: Reply with quote
Get a short breaker bar too, Ideal for not shaggin up ratchets on tough nuts. But don't go for a big one as you can put too much leverage and break the bolt.
https://www.toolweb.com/pics/KTI24080.jpg
Andy Sez....
F.Y.Y.F.F.
Gazdaman
I did a trackday!!!
PostPosted: 18:18 - 16 Jan 2006    Post subject: Reply with quote
If I can't get these off I'm not quite sure what I'm going to do.
I'll get a breaker bar and a new ratchet tomorrow, anyone recommend me heating it up beforehand?
Gaz
PostPosted: 18:31 - 16 Jan 2006    Post subject: Reply with quote
I wouldn't. If it is anything like my Jawa, there will be a rubber o-ring seal in there somewhere under the nut.
I have a big f-off ring spanner for undoing big nuts. It is like a giant double offset ring spanner cut in half in the middle of the shaft to give two stubby ones. You put it on the nut in question then batter the end of it with a lumphammer, this will crack most things loose. You can also put a bit of scaffolding tube over the end to form the worlds longest spanner.
I presume we are talking about the big one in the top of the fork stanchion that you would remove to get the fork springs out? They shouldn't really be all that tight Confused
Gazdaman
I did a trackday!!!
PostPosted: 18:42 - 16 Jan 2006    Post subject: Reply with quote
Yeah you're thinking of the right nut Stinkwheel.
I don't think it should be that tight, considering the engine mounts came off with no problems whatsoever. But apparently they're tight enough to break my eBay ratchet.
But I'd be surprised if these have ever come off before, so that's 16 odd years. I need to get the fork legs out, so I can mount the clipons. While they're out I may aswell change the fork seals and oil.
Gaz
Knowlsey
PostPosted: 19:03 - 16 Jan 2006    Post subject: Reply with quote
Had the same problem with the gs, must have been on since day one, luckily me mate had the windy gun handy, if you do use a windy watch out, we thought that we would catch it no problem, bollicks did we, at some point someone had put a spacer in to tension the spring to obviously stop the bottoming out, the spacer went flying along with the nut, but the spring stayed there, it was the only option as the nut wasnt going to come off, just to much bounce and movement to shock it off with a hammer and wrench
mchaggis
PostPosted: 20:25 - 16 Jan 2006    Post subject: Reply with quote
Put the bar at full lock, put the machine on the centre stand, and then use the spanner/ socket in such a fashion that you're pushing the bike backwards rather than sideways, if that is possible. Having the shaft of the spanner/ wrench perpendicular to the longitudinal axis of the machine should more or less do that. As shown in the attached image, it should minimise any turning moment of the machine (other than that caused by the fork not being on the longitudinal axis), and should mostly just push back onto the centre stand.
Also use an extender bar, the hollow handle of my 4lb lead mallet does the trick for me. The only problem is that then I have to hit it with the 2lb hammer instead. Smile
I must not be a troll...
Mmmm, Guinness
Gazdaman
I did a trackday!!!
PostPosted: 20:59 - 16 Jan 2006    Post subject: Reply with quote
The bike's so light it'd just skip along backwards, it works quite well wedging it against a wall.
I'll report back after I've tried a breaker bar on it.
Gaz
PostPosted: 21:07 - 16 Jan 2006    Post subject: Reply with quote
Sit on it. You will be directing the force through the bike frame then and not from the ground next to it, pulling yourself forwards with the same force as you are pulling the bike backwards.
Gazdaman
I did a trackday!!!
PostPosted: 21:58 - 16 Jan 2006    Post subject: Reply with quote
I can see the breaker bar slipping and removing one of my testicles..
Gaz
DucatiEVO
PostPosted: 22:25 - 16 Jan 2006    Post subject: Reply with quote
Have you tried giving the top a light 'tap' with a hammer to help dislodge the threads, then try going tighter before looser etc.
aKa: Ducky
Gazdaman
I did a trackday!!!
PostPosted: 22:34 - 16 Jan 2006    Post subject: Reply with quote
I've done the light tap, not tried doing it up before undoing though.
Gaz
mchaggis
PostPosted: 22:43 - 16 Jan 2006    Post subject: Reply with quote
Another approach requires the use of a 'soft-jawed vice', a woodworking one to you and me, with wooden jaws. Remove the stanchion from the machine and clamp it in the vice. With luck or a lot of rather old oak the workbench will stay put and the stanchion won't turn.
Mmmm, Guinness
plugger147
PostPosted: 22:57 - 16 Jan 2006    Post subject: Reply with quote
wedge the forks staight with a piece of wood,stradle the bike and grip it with your legs and pull on the breaker bar.
or just get a bloody impact driver. Laughing
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
Gazdaman
I did a trackday!!!
PostPosted: 23:02 - 16 Jan 2006    Post subject: Reply with quote
BTW, this is all so I can get the fork leg out. The bolt on the fork top is bigger than the hole in the top yoke. If I could get the stantion out, I wouldn't need to take this nut off.
If I really really have to, I'll have to take the headstock apart.
Gaz
Knowlsey
PostPosted: 01:37 - 17 Jan 2006    Post subject: Reply with quote
i would suggest you take it to your local garage as you said, if its not going to dislodge the crap on the threads, the windy gun will shock it off
DucatiEVO
PostPosted: 14:02 - 17 Jan 2006    Post subject: Reply with quote
If you were near Brands you could try my 18v Impact gun on it! That sucker undoes anything! Twisted Evil
aKa: Ducky
Knowlsey
PostPosted: 14:31 - 17 Jan 2006    Post subject: Reply with quote
Thats the jobby
The last post was made 20 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 130.88 Kb
