do you use car oil in your bike ?
old-git
PostPosted: 19:06 - 20 Jan 2006    Post subject: do you use car oil in your bike ? Reply with quote
just wanted to know if many of you use car oil instead of dedicated motorcycle oil .
i have always used castrol magnatec in my bikes ,
and had no problems , but wanted to here from other that might have a good reason for using bike oils ..
live long and prosper . Wink
Doddmaster
PostPosted: 19:49 - 20 Jan 2006    Post subject: Reply with quote
Car oils can cause the clutch the slip as they are not designed for that sort of use.
The best thing to do is use car oil in cars, and bike oil in bikes Shocked
old-git
PostPosted: 19:55 - 20 Jan 2006    Post subject: Reply with quote
clutch didnt slip on mine .
used it for 6 years .changed every 1000 miles Confused
tatters
Exxon Valdez
PostPosted: 19:56 - 20 Jan 2006    Post subject: Reply with quote
Thats only magentic that does that because of it addtives, car oil is fine to use in a bike plus its cheaper.
McJamweasel
BCF Junkie
Doddmaster is right (and what a shock it is to see him posting here - where the hell have you been?), car oils have all sorts of nasty additives that can cause clutch slip.
Doddmaster
PostPosted: 19:58 - 20 Jan 2006    Post subject: Reply with quote
What bike is it? You may have just been lucky, because it can definately cause clutches to slip
PostPosted: 20:00 - 20 Jan 2006    Post subject: Reply with quote
Suspect it's more of a case on more powerful bikes.
Had it on my 6r.
Have used cheap car oil when I had my dr600 no problems.
old-git
my bike is only a 125 ,maybe not enough power for the clutch to slip then .
has anyone here had clutch slip on a larger machine ..
or is it just what people think will happen Confused
old-git
PostPosted: 20:02 - 20 Jan 2006    Post subject: Reply with quote
as i thought .,,,anyone else ?
PostPosted: 20:06 - 20 Jan 2006    Post subject: Reply with quote
Note, that's cheap car oil.
I definitely wouldn't intentionally put expensive car oil with friction inhibitors in a bike again - would expect it will reduce clutch life even on smaller bikes.
Doddmaster
PostPosted: 20:07 - 20 Jan 2006    Post subject: Reply with quote
I've been enjoying the world of the (shock!) car for a while, but now I'm itching to get riding again, I'll be seeing you soon no doubt matey
Quote Me Happy
PostPosted: 20:08 - 20 Jan 2006    Post subject: Reply with quote
I use high quality bike oil in my bike - for peace of mind if nothing else. The price difference in the cheap/expensive oil isn't big enough to risk using the cheaper stuff in my (admittedly limited) opinion.
It would be at the back of my mind everytime I wound the throttle on if I'd used cheap stuff.
old-git
PostPosted: 20:10 - 20 Jan 2006    Post subject: Reply with quote
well in the real world ,i have had magnatec in my bike for 6 years ,,and it has been perfect ,,so has its life been reduced .
i have had absolutly no problem at all .bike runs like it was still new
so i am just lucky then
tatters
Exxon Valdez
"Waits for keith or stinkwheel to post"...........
old-git
PostPosted: 20:13 - 20 Jan 2006    Post subject: Reply with quote
30,000 klm on a 125 , with car oil .
Shocked
so due to explode any day now ? Laughing
mchaggis
PostPosted: 20:16 - 20 Jan 2006    Post subject: Reply with quote
It could be car oil for all I know, but really it's just mineral 10W40 at £3 a gallon. A CG engine needs nothing any better. My VT will be getting Castrol GTX I suppose, though that is £10 a gallon if you're lucky. One thing though, I do change my bikes' oils at perhaps twice the recommended frequency.
I must not be a troll...
Mmmm, Guinness
old-git
PostPosted: 20:19 - 20 Jan 2006    Post subject: Reply with quote
yes i think that is what is realy protecting it .but just my opinion
car oil , bike oil yeah right , it,s all 4 stroke engine oil .
prove me wrong someone ,,please Laughing
I think 125 clutches are sometimes just nabbed from bigger models, if this is the case, they can probably take a lot more abuse than most 125s will give out.
Even with all the slipping needed on most 125s, It's only very rarely that we hear about their clutches needing replacing.
old-git
PostPosted: 20:24 - 20 Jan 2006    Post subject: Reply with quote
i have never ,,and i mean never adjusted the clutch on my bike and i have done 30.000 klm on it ,, i know the cg engine is reliable .
but i dont think any other oil would make any difference .
difficult to prove unless you have several bike ,an a few years to do the testing i spose ..
PostPosted: 20:30 - 20 Jan 2006    Post subject: Reply with quote
Do you actually even slip the clutch much?
Never really heard of a cg clutch going - they don't really take much abuse at all due to low power etc.
I suspect that if we were talking maybe double that, yours would be more likely to go sooner.
Not really a problem for you on this bike, but definitely keep it in mind for a bigger bike.
You change the oil every 1000 miles on a cg with expensive car oil?
On my dr I was using £4.50 for 5 litres of asda cheap car oil -though it did drink it a bit.
old-git
PostPosted: 20:35 - 20 Jan 2006    Post subject: Reply with quote
well i do 5000 a year , and 5 lt of magnatec is £15 from a friend with a cash and carry store card .
..so it works out £15 a year to run on this oil .is that so bad do you think . Laughing
i now have just brought a new bike , another 125 as i like them ,and this time i think i might just use good old GTX or somethig like just to see if it fairs as well .
regards .,.,cliff
johnsilva
PostPosted: 20:42 - 20 Jan 2006    Post subject: Reply with quote
cars rev to 6000rpm
bike can rev to about 15000rpm nowadays
i dont see any argument here
Current Bikes: ZX7R P5; KR1S C2; GPX250R F3
Previously: CBR400RR-R; YQ50 Aerox
old-git
PostPosted: 20:45 - 20 Jan 2006    Post subject: Reply with quote
johnsilva wrote:
cars rev to 6000rpm
Laughing Laughing Laughing
a cg 125 are you taking the piss Laughing Laughing Laughing
old-git
PostPosted: 20:49 - 20 Jan 2006    Post subject: Reply with quote
anyway oil film strength is the same no matter what the revs
sorry to piss you off ..
old-git
PostPosted: 20:53 - 20 Jan 2006    Post subject: Reply with quote
come on chaps , i'm hoping to meet an oil, research and development technician here ..so we can find the definitive answer
The last post was made 20 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 130.67 Kb
