| Kram |
 Kram World Chat Champion
 Posted: 13:09 - 20 Jan 2006 Post subject: wtf.... i hate bikes |
Was planning on riding to plymouth for the weekend today, so i treated my bike to new oil, chain lube, air in tyres (usual stuff). went into town and my bike died on the way home....
blown my main 30amp fuse...., so i replaced it and it blew again, the ignition was off and the rectifer smoked...
what could be causing this??? i really need to get to plymouth.
Any ideas?
thanks
drummer ____________________ FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4 |
 Posted: 13:19 - 20 Jan 2006 Post subject: |
Sounds like there is a short circuit somewhere. Given that there was smoke coming from the rectifier, you have to be suspicious of that.
Disconnect the rectifier, bung a new fuse in and switch the ignition on. If it doesn't blow, you probably have the problem in your hand. Reconect it, if the fuse blows again that proves it.
You should be able to run the bike for quite a while on battery power alone (reg/rec disconnected) if you don't use the lights or electric start, just rememer that when the battery is flat, it stops. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kram |
 Posted: 13:20 - 20 Jan 2006 Post subject: |
will test now..
apart from i wanna ride 120 miles to plymouth  ____________________ FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4 |
| Kram |
| Kram |
| Kram |
 Posted: 23:03 - 20 Jan 2006 Post subject: |
I got an R6 regulator from a breakers yard earlier, had to do some wiring extensions as the new reg/rec is bigger, and i also had to take out the backing plate for the reg/rec. The thing works perfectly.
Just rode 130 miles with it, and it stayed cool, and charged the battery and everything is fine, for another 3 days (probably - just because i'm not using it )
So, it's a fairly easy mod, and hopefully should work better ____________________ FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4 |
| SimonB |
 SimonB Brolly Dolly
| Kram |
| SimonB |
 SimonB Brolly Dolly
The last post was made 20 years, 262 days ago. Instead of replying here, would creating a new thread be more useful? |
