4t 125 goes bang. Costly?
SoND
PostPosted: 16:19 - 21 Jan 2006    Post subject: 4t 125 goes bang. Costly? Reply with quote
My bike hasn't blew up, I'm just wondering if it does is it going to cost much to fix and would you be able to do it by yourself?
My rev counter hasn't been working for a while and I'm pretty sure I've went into the redline a few times. Whistle
Just want to know what I'm looking at if it ever decides to shit itself. Neutral
PostPosted: 16:23 - 21 Jan 2006    Post subject: Reply with quote
Depends what goes wrong, but the chances are it will cost rather more than a typical 2 stroke engine blow up.
lilredmachine
PostPosted: 17:00 - 21 Jan 2006    Post subject: Reply with quote
*hugs his rev limiter*
mchaggis
PostPosted: 18:41 - 21 Jan 2006    Post subject: Reply with quote
Keep on top of the oil changes and you can rev it a lot. It's when you let it get low on oil where it starts having big problems. Even then, it's entirely possible it could free itself if it seizes when it's too hot.
I must not be a troll...
Mmmm, Guinness
craigs23
Mr Muscle
PostPosted: 19:06 - 21 Jan 2006    Post subject: Reply with quote
Not sure, 125cc engines can't be that pricey though?
veeeffarr
PostPosted: 19:33 - 21 Jan 2006    Post subject: Reply with quote
Hmmm, A bit off topic but not worth starting a new thread for, is it possible to fit a tachometer on a bike that doesn't have one? Wouldn't mind one for the CG.
mchaggis
PostPosted: 19:42 - 21 Jan 2006    Post subject: Reply with quote
If you can find some part of the ignition circuit to take a trigger voltage from and somewhere to mount it, then I don't see why not. You'd need to extend the wiring loom for lighting it, but that wouldn't be especially tricky.
Mmmm, Guinness
mr.z
PostPosted: 19:43 - 21 Jan 2006    Post subject: Reply with quote
You can fit one, it picks up the magnetic field in the ht lead.. so very simple to fit..
But it honestly really isn't worth haveing one... if you need one then somethings wrong, once your past the stage where you need it to guage clutch pull revs e.t.c. or for runing in.. i guess on a biger bike its interesting to know your cruiseing revs on the motorway..
but with a 125 then you should be spanking it almost everywhere anyway Razz
PostPosted: 20:18 - 21 Jan 2006    Post subject: Reply with quote
Typical failure on a 2 stroke is a heat seizure. New piston and repair barrel. Easy enough to do.
On a 4 stroke there is rather more to go wrong. Drop a valve, snap a cam chain, fail to keep the oil level up and the bill will be large. Snap a con rod and the bill will be larger.
colezxr
PostPosted: 20:28 - 21 Jan 2006    Post subject: Reply with quote
what bike is it
Its better to live your life for one hour as a tiger, Than it is to live your whole life like a worm.
past: gilera dna125. kawasaki zxr400h1, honda cbr 900rrr fireblade (currently being sold for parts). present honda hornet 900
SoND
PostPosted: 18:16 - 22 Jan 2006    Post subject: Reply with quote
If you took enough time would it be something you could learn to do yourself?
It's a GS125. Don't think it's ready to blow up just yet.
PostPosted: 18:46 - 22 Jan 2006    Post subject: Reply with quote
Depends on what goes wrong. Snap a cod rod and there is a fair chance that major components will be wrecked which will make it totally uneconomic to repair.
For a rough example, my 1200 Bandit jumped a few teeth on the cam chain. Result was 16 bent valves (no apparent piston damage). That is £300 just for the valves from Suzuki, let alone replacing any damaged valve guides or the gaskets.
lilredmachine
PostPosted: 19:50 - 22 Jan 2006    Post subject: Reply with quote
I lost an MZ 4 stroke 125 motor on E-bay recently. It went for £100. That's for a 2003 DOHC, 4 valve head motor.
Would cost more than that in labour for a garage to look at it probably.
The last post was made 20 years, 170 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 80.7 Kb
