Urgent: CG125 Sump nut size?
Brick_Top
PostPosted: 13:35 - 22 Jan 2006    Post subject: Urgent: CG125 Sump nut size? Reply with quote
I don't have a large socket for my sump nut, it appears to be about 24mm using a tape measure to measure it (don't have anything more accurate than this)
Can anyone confirm this, so I can go and buy the socket?
Con
NSR Mick
PostPosted: 13:57 - 22 Jan 2006    Post subject: Reply with quote
That seems a little large to be honest, do you have the right bolt they are usually about 17-19mm.
veeeffarr
PostPosted: 14:01 - 22 Jan 2006    Post subject: Reply with quote
24mm bolt yeah that's right, for the bolt under the gear selector?
It's a large bolt yeah, 24mm should do it.
Brick_Top
PostPosted: 14:27 - 22 Jan 2006    Post subject: Reply with quote
It was 24mm, i went down to halfords and chanced it Smile
Brick_Top
PostPosted: 14:30 - 22 Jan 2006    Post subject: Reply with quote
Now the questions is what torque should I do it up to
Brick_Top
PostPosted: 14:46 - 22 Jan 2006    Post subject: Reply with quote
Whats this spring all about??
TimC
PostPosted: 15:08 - 22 Jan 2006    Post subject: Reply with quote
that spring is to keep the oil filter pressed in, also make sure u dont lose the small rubber ring that goes on the end, keeps it all fitting nicely, dont tighten it to tightly, i did to my cg and took ages to get it back of!
CB400sf version s, d&d race can and a few other odds and ends!
Brick_Top
PostPosted: 15:28 - 22 Jan 2006    Post subject: Reply with quote
All done and running smoothly Smile
The last post was made 20 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.87 - MySQL Queries: 13 - Page Size: 53.97 Kb
