how to re jet a carb
shager
PostPosted: 21:23 - 22 Jan 2006    Post subject: how to re jet a carb Reply with quote
hi iv heard that rejettin a carb can make my bike go faster, or by changin the position of the floats can any 1 tell me how to do this??
PostPosted: 21:50 - 22 Jan 2006    Post subject: Reply with quote
Didn't you land up with the throttle valve in the wrong way round/needle off or something last time?
I would leave your carb well alone for the moment, they are a precision piece of engineering and you shouldn't fiddle with them unecessarily. I understand how they work and I don't touch them unless I think something is wrong. I advise you do the same.
Rejetting ther carb in itself will not make your bike faster unless it is in conjunction with other modifications. Get the jetting wrong and you could seize your engine.
NSR-Rulez
Rejetting wont make a bike go faster it will make the bike run lean or rich, rejetting only usually needs to be done when you use aftermarket exhaust systems, or derestrict a 2 stroke.
NSR-Rulez
Past: 1985 Suzuki GS 125 + 2002 Honda NSR 125 R-2 + Ford Fusion
Present: Honda CBR 600 RR-5 + Suzuki SV650S-K4 + Mitsubishi FTO GPX
fuzz
PostPosted: 00:02 - 23 Jan 2006    Post subject: Reply with quote
It can make your bike go faster, coupled with a performance exhaust system and air filter, and some dyno time to get it right.
Not only can you rejet, but as you say, you can alter the float height, aswell as the needle height and altering air/fuel ratio. As you can see, it's not a simple matter of swapping a couple of jets over and hey presto, but rather a complex procedure best left for someon who knows what they're doing.
Basically it goes:
Main jet - Full throttle/high RPM operations
Needle position - Midrange richness
Float height - Low end power
Mixture screw - Idle and low RPM smoothness
Trouble is, changing one thing affects the others, so it's not as black and white as this.
Klause
PostPosted: 15:00 - 23 Jan 2006    Post subject: Reply with quote
I bored out my orginal exhausts to make them louder and free flowing. I changed the needle position's recently (richer) and it pulls so much better in the midrange rev's now Thumbs Up .
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
puremagic72
PostPosted: 17:52 - 23 Jan 2006    Post subject: Reply with quote
you mean needle second from top?
Baz. Laughing
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
puremagic72
Baz. Laughing
Klause
PostPosted: 02:18 - 24 Jan 2006    Post subject: Reply with quote
Baz. Laughing
Who? Laughing
puremagic72
PostPosted: 06:58 - 24 Jan 2006    Post subject: Reply with quote
the needle position!!
Mr. Green
The last post was made 20 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 60.38 Kb
