| kawakid |
 kawakid World Chat Champion
| mchaggis |
 mchaggis World Chat Champion
 Posted: 11:23 - 24 Jan 2006 Post subject: |
Give them leather food, wax, Nikwax and then just wear them. You'll get used to them and they'll get broken in as you wear them. They shouldn't be quite as bad as a new pair of boots, they won't be grinding skin from your heels and chafing your calves for instance. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| kawakid |
| mchaggis |
| numark1 |
 numark1 Scared of girls
 Posted: 11:55 - 24 Jan 2006 Post subject: |
My leathers never broke in fully when i had them (dainese tribal) it's annoying becuase you can barely move.
Wear them around the house.  |
| kawakid |
| queen of string |
 queen of string World Chat Champion
| Simple |
 Simple World Chat Champion
| Superlight |
 Superlight Nitrous Nuisance
 Posted: 13:45 - 24 Jan 2006 Post subject: |
They do need to be tight, but you need to be able to move.
What you don't want is a loose fit when you first put them on, cos that means saggy bum once they're broken in!
I used to wear mine around the house and watching TV when I first got them.
The quickest way to ruin leather is get it really wet, then dry it over a radiator. It'll go like cardboard! If (when) you do get 'em wet, they have to be dried out slowly, and then treated so they stay flexible. Nikwax is good stuff, it's waterbased so you can put it on wet leather and it stays soft as it dries.
Mine are about ten years old now, I think they've stopped getting more comfortable each time I wear them.
Which probably means it's about time I got some new ones!  ____________________ You only need two tools: WD-40 and Duct Tape.
If it doesn't move but should, use the WD-40.
If it shouldn't move but does, use the Duct Tape. |
| BFG |
 BFG Brolly Dolly
 Posted: 14:33 - 24 Jan 2006 Post subject: |
This post edited many times as I was checking the info.
Old Nikwax and saddle soap, together with many other leather care products can rot and therefore seriously weaken stitching.
Not a problem for a horse saddle, but fairly disastrous when you're sliding along asphalt on your arse.
I use Grangers. I think new water-based Nikwax is OK. Needs checking. But bung that old tin out!
Saddle soap is still a no-no unless it says on the tin that it won't rot stitching! |
| stinkwheel |
 Posted: 15:47 - 24 Jan 2006 Post subject: |
Best way to break them in quickly is to go out riding your bike on a showery day so they get damp and keep riding it until they are dry again. Give them some leather treatment when you get back and they will fit like a glove.
Leather treatment is probably best applied with your hands (the heat helps it penetrate into the grain), or even better, get a very good friend to apply it while you are wearing them
I use nikwax on my leathers and my combat boots. I have had the leathers for ten years with no apparent ill effects. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 20 years, 263 days ago. Instead of replying here, would creating a new thread be more useful? |
