brakes not working when bike tilted ??
skint
PostPosted: 12:05 - 24 Jan 2006    Post subject: brakes not working when bike tilted ?? Reply with quote
I have a track bike ( year 2000 R1 ) and a trailer I use to transport it on. Today, whilst backing it off the trailer and halfway down the ramp (ie with the front of the bike pointing into the air) i noticed that the front brake lever had gone all floppy and the front brake didnt work ... once I'd moved it back a little more so that the front end wasn't pointing up as much it started working again ok. I'd assumed that the front brake system is a fully sealed pressurized system which shouldn't be effected like this -- am I correct ?? Could it be that there's some air in the system and the brakes need bleeding ??
Thanks,
skint
feef
Energiser Bunny
PostPosted: 13:29 - 24 Jan 2006    Post subject: Reply with quote
there IS fluid in the reservoir ins't there? tilting the bike back could expose the feed hole in the bottom if the fluid's low.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
BFG
PostPosted: 13:32 - 24 Jan 2006    Post subject: Reply with quote
Agreed. You probably leaned it over so far that all the fluid uncovered the feed hole. Probably needs more in it, or, don't operate the levers when the bike is leaned so far over.
skint wrote:
ICould it be that there's some air in the system and the brakes need bleeding ??
There will be now Wink The fact the lever went floppy means it has pushed some air into the system and it should be bled. Specially if it's a track bike.
skint
PostPosted: 14:02 - 24 Jan 2006    Post subject: Reply with quote
The resevoir fluid level is fine. If its the case that leaning the bike over/back might cause air to get into the system then what about when you go up/down a very steep hill or the bike falls over ????
skint
BFG
PostPosted: 14:14 - 24 Jan 2006    Post subject: Reply with quote
For some reason I was thinking of leaning it over sideways, sorry. Front and back it would need a hell of an angle to uncover the feed hole.
There must be something else wrong. At this stage I would be planning a master-cylinder rebuild. Sudden loss of pressure is rare.
It could be that there was air in the system trapped somewhere, and different vibration of the trailer made the bubbles rise to the master cylinder - but this is a guess.
I would try and replicate the problem, paying careful attention to the circumstances. It may help diagnose the problem.
Or maybe try bleeding it and then some careful test rides.
skint
PostPosted: 14:26 - 24 Jan 2006    Post subject: Reply with quote
ok, thanks BFG. I will see if i can reproduce the problem tonight when I take the bike off the trailer again... If I can i'll bleed the system and then try again. Will let you know what the problem turns out to be.
skint
feef
Energiser Bunny
PostPosted: 15:28 - 24 Jan 2006    Post subject: Reply with quote
I know someone, years ago when sarting out at DIY maintainance who topped up the brake fluid, and was adamant it was fine. problem is, they simply removed the reservoir cap and poured it in.. didn't know to remove the rubber expansion seal... they jad just filled that lol
and no.. it wasn;t me
honest
Razz
a
ancientd
PostPosted: 17:24 - 24 Jan 2006    Post subject: Reply with quote
Do you have the standard front brake set up with a remote fluid reservoir or has it been converted to a combined Master cylinder and reservoir? If it's a remote type then check that the reservoir is mounted properly and that the connecting pipework to the master cylinder is properly clamped with no leaks. It is possible for air to get in if the connections are not sound.
I ride 3 bikes, a Thundercat, an FZRexup 1000 Streetfighter and a Jawa 350 Combo, something for all seasons.
Guest
PostPosted: 17:30 - 24 Jan 2006    Post subject: Reply with quote
If you've just had the front end in the air you won't need to bleed the brakes in the conventional sense - air doesn't travel well down hill.
As said, you probably just exposed the the hole that the piston forces the fluid down. With the bike back on the level the air will migrate back to the top of the hose and be sat there waiting for the next time you squeeze the lever - then it'll bubble back into the reservoir and you'll get your brakes back Thumbs Up
The last post was made 20 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 61.49 Kb
