bike test this friday. any help?
Biker_Dene
PostPosted: 23:29 - 24 Jan 2006    Post subject: bike test this friday. any help? Reply with quote
got my bike test on friday
has any 1 got any tips they can give me?
i heard that ou dont use your indicators on your U turn is this right?
and what is the instructor looking for anything i should concentrate on more than anything else?
thanks
Dene
Groove
PostPosted: 00:14 - 25 Jan 2006    Post subject: Reply with quote
Have you done any training? Shocked
You should not use you indicator on a u turn, no. There should be no traffic around for you to indicate too.
Dont put you feet down on u turn either, only use rear brake to slow you down during it. Also make sure you do plenty of observations when doing the u turn and walk it round.
Thumbs Up HTH
gimpy limp
PostPosted: 01:10 - 25 Jan 2006    Post subject: Reply with quote
theirs a trick to u-turns, I was doing it fine without learning this but once I did it became so much easier, you have to keep your throttle open on a decent amount of revs (more revs better than too little and you can't fail on revving the nuts off it) then use your clutch to move off and perform the maneuver whilst keeping that throttle at the same revs throughout easing the clutch in and out. The only time you indicate on a u turn is if a car is coming down the road which you hadn't spotted before you started the maneuver (best to wait till theirs no chance of a car coming either side so you dont get flustered with indicating as its difficult.
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
nrml76
PostPosted: 09:35 - 25 Jan 2006    Post subject: Reply with quote
Never focus on the kerb while doing a U turn. Focus on the end of the road. If you look at the kerb, you will hit it.
killa
Won't Shut Up
PostPosted: 09:51 - 25 Jan 2006    Post subject: Reply with quote
Good observation and control is the key, TO ALL MANOUEVRES!.
You have to look up the road whilst doing it, so get comfy, get the control and the looking comes easy.
The emergency stop, or ‘controlled stop’ is just that, it’s not a case of slamming on the brakes.
Pulling away from the rear of a park car is easy, cant do that, you shouldn’t be riding. Wink
Everything else is simple enough, what I did was imagine what the examiner can see behind you, you might think you look ok but he/she might not think you’re looking.
Good luck. Thumbs Up
Cillit-BANG
PostPosted: 09:56 - 25 Jan 2006    Post subject: Reply with quote
As far as general riding goes, the instructor is looking to see if you are a competent and safe rider. Provided you are confident in your own biking skills, then make sure this comes across, and you'll be fine.
Don't get too hung up on the maneuvers.
Just relax, and ride so you look comfortable on a bike.
Cillit-BANG
PostPosted: 10:00 - 25 Jan 2006    Post subject: Reply with quote
And don't be afraid to use the throttle, the instructor knows exactly how fast bikes will go, and will prefer to see that you can handle that power, if you twindle up to 60, how's he going to know that when you get out on your own, your not going to spin the rear wheel up the first time out?
If you can safely overtake within the speed limit, then why not? You would in the real world.
Don't filter though. For 1, your test can only last 45mins so the more time your sitting still, the less time you have to mess up!
And good luck.
danzai66
PostPosted: 10:24 - 25 Jan 2006    Post subject: Reply with quote
And good luck.
is this true? what do they think of filtering? i filter alot (well, a fair bit) because i've started to commute in london. without filtering it would take me ages to get home...
Whosthedaddy
PostPosted: 10:35 - 25 Jan 2006    Post subject: Reply with quote
danzai66 wrote:
And good luck.
The examiner wants to see you make good progress ie overtaking slow moving traffic, filtering may seem dangerous as you are too close to cars either side
superstacker
PostPosted: 10:51 - 25 Jan 2006    Post subject: Reply with quote
Dont filter on your test, theres too much that can go wrong.
Ride in a safe sensible manner and look like you belong on the road!
I really think you should be asking your instructor these questions, he knows your riding much more then we do Smile
danzai66
PostPosted: 10:57 - 25 Jan 2006    Post subject: Reply with quote
furry muff.
killa
Won't Shut Up
PostPosted: 10:58 - 25 Jan 2006    Post subject: Reply with quote
Yeah I was wondering that, hasn’t your instructor made you feel confident about all this?
Anyway, when performing the controlled jump, make sure you clear the cones, I saw some chap break his leg.
Wink Thumbs Up
Whosthedaddy
PostPosted: 11:01 - 25 Jan 2006    Post subject: Reply with quote
I found that the stoppies were the hardest to perform under pressure
danzai66
PostPosted: 11:44 - 25 Jan 2006    Post subject: Reply with quote
i found it hard to perform under pressure too...
*sniff*
hung like tard, blubbing with stage fright.
...sorry.
going a way now.
Smile
Superlight
PostPosted: 12:17 - 25 Jan 2006    Post subject: Reply with quote
I have to agree with that. My wife failed a DAS test because of filtering.
Her instructor never told them much about filtering, but said on the day of the test "oh, they like progress, so a bit of filtering will impress them".
She saw a gap in a traffic queue and took it. Ended up with her back wheel just over the line into a right turn lane. (Of course I've never done that!)
That was her only fault! Thumbs Down
Be confident, and enjoy it.
Good luck.
You only need two tools: WD-40 and Duct Tape.
If it doesn't move but should, use the WD-40.
If it shouldn't move but does, use the Duct Tape.
greatmoorred
PostPosted: 10:36 - 26 Jan 2006    Post subject: Reply with quote
oh, and dont be late. I was, and the examiner wasnt very happy Thumbs Up
NitroNorry
PostPosted: 10:45 - 26 Jan 2006    Post subject: Reply with quote
One thing my instructor didn't really tell me beforehand was that the examiner will ask you to pull over to the left a few times. They often do this when there are places you MUST NOT stop, such as zig zag lines etc. Best check you know where you are and are not allowed to stop.
Otherwise, relax, ride assertively and show that you are making observations.
Martin
Triumph Daytona 675
www.triumph675.net
Mags
PostPosted: 15:08 - 26 Jan 2006    Post subject: Reply with quote
Watch out for no car lanes and bus lanes mine took me to both. I nearly avoided the no car lane and dived into it just after it started. He gave me a minor fault for it. Id have failed if I hadnt gone in it.
Cillit-BANG
PostPosted: 15:49 - 26 Jan 2006    Post subject: Reply with quote
Watch out for the examiner saying 'Take the next available right turn'. available means exactly that, they will often say it just before a no-entry turn, so keep awake!
The last post was made 20 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 104.68 Kb
