Re- Jetting
JonB_5
PostPosted: 23:20 - 25 Jan 2006    Post subject: Re- Jetting Reply with quote
Just got a new can on my bike, which is restricted to 33bhp, do i need to get it re jetted, and if so will i then have to get it re jetted again after i take the restrictors out??
Thanks
Jon
SoND
PostPosted: 23:23 - 25 Jan 2006    Post subject: Reply with quote
Check your spark plugs to see if it's running lean or not. If it is, get it jetted.
fuzz
PostPosted: 23:36 - 25 Jan 2006    Post subject: Reply with quote
I wouldn't think a restricted bike would be running lean. It might need up jetting when derestricted, but with only an end can, it's unlikey.
PostPosted: 23:41 - 25 Jan 2006    Post subject: Reply with quote
In theory you probably do. Checking plugs on a 4 stroke will not go you much (just tells you the mixture on the "throttle position" you were last using, but with CV carbs the throttle position and the mixture are not really 100% dependent on each other).
riichy
PostPosted: 23:53 - 25 Jan 2006    Post subject: Reply with quote
my bikes 33bhp and have a art race can...if its just the end can you have dont bother Thumbs Up
.......... PLOD ............ zx636 2004
The#Doctor#
PostPosted: 13:19 - 26 Jan 2006    Post subject: Reply with quote
Mine lost 40bhp with 'just an end can' but mine is not restricted so wouldn't know but if your in any doudt get it on a dyno
CBR125R - CBR600Fy Smile
'140 mph officer thats impossible the bike is 33 bhp restricted'
ancientd
PostPosted: 13:39 - 26 Jan 2006    Post subject: Reply with quote
Changing the can on a restricted bike should not make a lot of difference, but be sure your restriction paperwork does not specify the end can used. When the restrictors are out I would advise checking the set up on a Dyno just to prevent engine damage, above all don't change the jets unless you can have it properly set up, you are liable to mess up the performance unless you get it set up.
I ride 3 bikes, a Thundercat, an FZRexup 1000 Streetfighter and a Jawa 350 Combo, something for all seasons.
The last post was made 20 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.13 - MySQL Queries: 13 - Page Size: 52.3 Kb
