No cotter pin?
LustyLew
PostPosted: 10:27 - 26 Jan 2006    Post subject: No cotter pin? Reply with quote
Just tighened the chain on the bandit for the first time last night. According to the service book you have to remove the cotter pin and replace, I was going to use an R pin instead. However, there is no hole in the axle for the pin to go through! Shocked
I would have thought this is pretty dangerous, especially if the rear nut decides to loosen itself.
Would somethigng like thread lock do the trick?
Superlight
PostPosted: 13:13 - 26 Jan 2006    Post subject: Reply with quote
Hello mate,
I don't think I'd use thread lock on an axle bolt, you'll be undoing it too often (if you adjust your chain as often as you should Wink ).
I would've said that if the bolt is tightened to the correct torque and the washer's in good condition, it should be fine. A lot of bikes don't have pins anyway.
BTW - You say there's no hole in the axle, but do you have a castellated nut? If not, they probably changed the design, and the handbook wasn't updated.
You only need two tools: WD-40 and Duct Tape.
If it doesn't move but should, use the WD-40.
If it shouldn't move but does, use the Duct Tape.
ancientd
PostPosted: 16:05 - 26 Jan 2006    Post subject: Reply with quote
Surely you mean a Split pin? a cotter pin is something else, it actually locks into the shaft in which it sits and is usually locked in place with a nut of its own. Many bikes don't use a split pin and have a self locking type nut, but if you should have one it really ought to be replaced.
I ride 3 bikes, a Thundercat, an FZRexup 1000 Streetfighter and a Jawa 350 Combo, something for all seasons.
BlackSheep
PostPosted: 16:58 - 26 Jan 2006    Post subject: Reply with quote
The bandit does not have a split pin , the rear axle is torqued up instead , on the 1200 it is torqued to 100 Nm , i don't know what it should be for 600 , you will need to check the manual.
GSXR 1100 StreetFighter
ZRX61
Victor Meldrew
PostPosted: 17:09 - 26 Jan 2006    Post subject: Reply with quote
Split pins are also called cotter pins. What you're talking about seems to be a taper pin.
ancientd
PostPosted: 17:21 - 26 Jan 2006    Post subject: Reply with quote
A cotter pin is a tapered pin that is pulled into a shaft and fitments combination to lock the fitment to the shaft and is locked in place by a nut on a thread on the small end of the pin, as in the old style pedal cycle pedals. The split pin simply goes through the shaft and is opened up to prevent anything that is on the shaft moving past the pin, also used in conjunction with a castellated nut to prevent the nut from turning. They are two totally different things, well in the UK at least.
Kris
PostPosted: 17:26 - 26 Jan 2006    Post subject: Reply with quote
You worry too much Laughing
Just do the axle bolt up nice and tight and you'll be fine. The Bandit isn't a bike I'd worry about things like that on matey Thumbs Up
www.prisonplanet.com
ZRX61
Victor Meldrew
PostPosted: 17:29 - 26 Jan 2006    Post subject: Reply with quote
I'm well aware of what things are called in the UK. However, the rest of the planet calls split pins cotter pins & what you call cotter pins are commonly known as taper pins.
ancientd
PostPosted: 17:33 - 26 Jan 2006    Post subject: Reply with quote
Sorry, I'll bow to your obvious more experience in this matter and not argue, but I'll still call them by the right name that I've called them by for over 50 years.
ZRX61
Victor Meldrew
PostPosted: 17:39 - 26 Jan 2006    Post subject: Reply with quote
I call em by both names, depending on who I'm talking to.
BlackSheep
PostPosted: 17:48 - 26 Jan 2006    Post subject: Reply with quote
Wheel's can fall off bandit's too , you can also wreck your wheel bearings by over tightening.
mchaggis
PostPosted: 21:14 - 26 Jan 2006    Post subject: Reply with quote
If it is supposed to take 100Nm, I don't really think that overtightening it is really likely to be that much of a concern for him, unless he's jumping on the wrench. Smile
I must not be a troll...
Mmmm, Guinness
MikeH
PostPosted: 22:15 - 26 Jan 2006    Post subject: Reply with quote
Sorry had to check Rolling Eyes and it surprised me.
Definition of a Cotter Pin
Clicky Clicky Linky
I must admit I've always called the tapered pins in the pedals of a pushbike cotter pins, and the pin for a castlated nut a split pin.
Done my chain tonight and the split pin snapped so will have to get one tomorrow, rather be safe than sorry.
Mike
Busa Junkie
Superlight
PostPosted: 22:41 - 26 Jan 2006    Post subject: Reply with quote
Ha!
Don't worry guys, I've got a torque wrench LH can use to get his nuts sorted!
I was gonna put that in my post, but I PMd him instead, cos I had visions of becoming the South East tool lending mug. He did point out that I could charge, so if anyone else is a few tools short...
Idea
LustyLew
PostPosted: 23:32 - 26 Jan 2006    Post subject: Reply with quote
There's only one person on this forum who's allowed to torque my nuts. I'm afraid it's not you. Razz Wink
ZRX61
Victor Meldrew
PostPosted: 17:36 - 27 Jan 2006    Post subject: Reply with quote
Clicky Clicky Linky
Wheres the "smug git" smilie? Wink
ancientd
PostPosted: 19:35 - 27 Jan 2006    Post subject: Reply with quote
It would be of more interest if it was a British site but it's American, hence my comment about in the UK. In America a split pin is called a Cotter pin and the terminology is spreading to the UK, but it don't make it right.
MikeH
PostPosted: 20:54 - 27 Jan 2006    Post subject: Reply with quote
Spot the Difference Question
Cotter Pins
Split Pins
Even UK suppliers are confused what hope do we have Laughing
Busa Junkie
ancientd
PostPosted: 21:34 - 27 Jan 2006    Post subject: Reply with quote
No chance at all.
www.125power.com
PostPosted: 01:33 - 28 Jan 2006    Post subject: Reply with quote
There is a difference.....you know when you fit a split pin and then months later need to remove it but the ends are all fucked up and knotted and you have no idea how? Takes ages of prying with screwdrivers and pulling with long nose pliers.
Well the latter is a cotter pin because its all knotty and shitty bit like when a girl has a head full of cotter's not a nice thing i must say Laughing
My eBay Items
The last post was made 20 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 109.19 Kb
