Bike won't catch after winter rest
innominate
PostPosted: 08:20 - 26 Jan 2006    Post subject: Bike won't catch after winter rest Reply with quote
Hi,
My CB500 wont start after sitting for a few months.
Battery is fine and the starter motor turns without a problem.
Does not catch though.
I noticed I had left the fuel tap on by mistake all winter.
What should i check, step by step to get it to start running again?
I would guess (with my limited knowledge) that something could have blocked the carbs?
I, as a responsible adult human being, will never concede the power to anyone to regulate my choice of what I put into my body, or where I go with my mind. From the skin inwards is my jurisdiction, is it not? I choose what may or may not cross that border. Here I am the customs agent. I am the coast-guard. I am the sole legal and spiritual government of this territory, and only the laws I choose to enact within myself are applicable.
the grim reaper
PostPosted: 13:34 - 26 Jan 2006    Post subject: Reply with quote
If it's turning over, my first guess would be fuel. How long has it been stood for? Modern petrol goes off in a matter of weeks, I would recommend cleaning out the carbs, draining the tank and trying fresh fuel. If that doesn't work, take the plugs out and see if they're wet with fuel or not. If they are then you have an electrical problem.
My guess would be fuel though.
Grim
carvell
Scuttler
PostPosted: 13:42 - 26 Jan 2006    Post subject: Reply with quote
Take the carbs off, give them a clean, put them back on.
I had exactly the same problem - this will fix it.
Yamaha TDM 850
Superlight
PostPosted: 15:31 - 26 Jan 2006    Post subject: Reply with quote
Sounds about right - once the volatile parts of the fuel have evaporated, you're left with 'gunge' in the carbs.
When you lay a bike up for a while, it's worth draining the tank (or at least running it down to reserve) and the carbs (run the engine with the fuel tap off), or use a stabiliser additive. That should help with getting it going again come spring.
I assume somebody's done the "how to store a bike" guide here before? I couldn't see it, but I admit I didn't look far.
You only need two tools: WD-40 and Duct Tape.
If it doesn't move but should, use the WD-40.
If it shouldn't move but does, use the Duct Tape.
mchaggis
PostPosted: 16:27 - 26 Jan 2006    Post subject: Reply with quote
My VT is being a bastard to start when it (the weather) gets cold. It works fine when it's warm, but give it anything much colder than five degrees and it decides to go on holiday. It had been stood over the winter and half of last year too, so I guess stripping and cleaning the carbs is something I really should have done already. Embarassed
I must not be a troll...
Mmmm, Guinness
The last post was made 20 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 45.36 Kb
