yamaha virago 125 oil drain plug removal
Richard1987
PostPosted: 18:16 - 27 Jan 2006    Post subject: yamaha virago 125 oil drain plug removal Reply with quote
Hello, got this virago that needs an oil change, only the clever people at yamaha have positioned the engine in such a way that the frame is half covering it (cant get a socket on it) and the gap between the frame and the plug is so tight, a normal spanner wont fit in, any ideas? anyone... Smile
some ideas ive had is to loosen the engine bolts and just move the engine over a little (but its quite a hefty engine for a 125) and generally seems too much hassle just for an oil change?
cut the offending bit of frame away and weld a piece of tube in that clears the drain plug so that a socket is easily fittable Cool
craigT19
Jolly Green Giant
PostPosted: 23:36 - 27 Jan 2006    Post subject: Reply with quote
a spanner normally does the job mate, not sure what u mean by the gap is too small to get a spanner in? cos if thats the case u wont have enough room to take the plug out anyways..
off the top of my head normally use the ring end of the spaner, hit it with your palm to losen then take the spanner away then undo it by hand?
if i have my wire crossed ill let u know when im at work tomorrow and can have a look at one.
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
mchaggis
PostPosted: 23:41 - 27 Jan 2006    Post subject: Reply with quote
Whatever you do, don't overtighten it when you come round to putting it back on. I was lucky in that I was dealing with an alloy filler cap in a cast steel final drive hub, if you've a steel drain plug in an alloy casting, it's rethreading time = Pound Coin Pound Coin, not just time for a new drain plug.
I must not be a troll...
Mmmm, Guinness
Richard1987
the gap between the plug and the frame is quite small. the ring spanner is just too fat, even the thin low quality ones wont fit, cant get the ring over the nut ? ill try and get some pictures to show you what i mean tomorow
add me to your msn messenger contacts : [email protected]
craigT19
Jolly Green Giant
PostPosted: 00:24 - 29 Jan 2006    Post subject: Reply with quote
silly question but u sure u got the right bolt?
you should be looking for a 17mm bolt on the left hand side of the engine?
Richard1987
PostPosted: 00:28 - 29 Jan 2006    Post subject: Reply with quote
yes, i have the right bolt, it is a 17mm bolt too
i Will double check tomorow but im 100% sure it is Rolling Eyes
Richard1987
PostPosted: 21:31 - 29 Jan 2006    Post subject: Update Reply with quote
it is the oil drain plug bolt that is behind a piece of frame Smile
Still screwed into the Evil or Very Mad
The last post was made 20 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 52.71 Kb
