Arsin' battery
Going2fast
PostPosted: 13:28 - 28 Jan 2006    Post subject: Arsin' battery Reply with quote
Can not believe it, one day of no use and its dead Crying or Very sad
And before its day of non use it had covered 45 miles in 2 days, so it should be charged. Very strange and never happened to me before on this bike (CBR Fsport).
Any one think of a reason why this has happened?
Thinking an optimate is a good investment, after which ive paid to have my downpipes fitted as the peg has welded it self to the bolt which is connect to the manifold. As you can tell a shitty week for my motorcycling Evil or Very Mad Thumbs Up
Andy
Passed My Test 15/03/05 Very Happy Very Happy
BikePics Profile ||| 96' RVF 400 ||| 01' CBR 600 F Sport ||| 2009 Yamaha YZF-R6 Delivered 23/06/09
/-\ndy
Teaman
PostPosted: 16:06 - 28 Jan 2006    Post subject: Reply with quote
You checked the levels at all?
If there low top up with distilled water and whack an optimate on it,
Trickle chargers are crap, because they can overcharge,
optimates, er, mend batteries and those they cant mend need throwing Smile sound investment imo
as to why its happened? dunno, some bikes are left on side stand all the time causing the batteroe to be on a tilt making it leak,
alternators duff? doubtfull on this as its easy enough to check,, check if your lights go bright when you rev the bike, if so its fine.
hope that helps,
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
Going2fast
PostPosted: 19:00 - 28 Jan 2006    Post subject: Reply with quote
Cheers Thumbs Up
Brought an optimate. Hopefully that will sort the job.
Andy
/-\ndy
Going2fast
PostPosted: 12:45 - 29 Jan 2006    Post subject: Reply with quote
Sad Still dont work Sad
Hearing all the correct noises but bike never jumps into life. Checked kill switch, just in process of taking fairings off, as had them off and when i put them back on the problem started. Maybe hit a wire, hopefully. Just getting me down Sad
/-\ndy
Teaman
PostPosted: 12:58 - 29 Jan 2006    Post subject: Reply with quote
So I'm right in saying the battery is turning the engine over?
just no brum.
you checked the plugs?, ht leads (are they hardened with age) is there a spark?
so on ,, you tryed bumping the bike?
Going2fast
PostPosted: 13:24 - 29 Jan 2006    Post subject: Reply with quote
Fi, Cannie bump them as far as i know then again i am a n00b at these things.
Yup you are correct, thinking maybe flooded. Thing is battery has just died again after just two short turn overs. Battery problem? Just weird for it to just died just over night.
/-\ndy
Teaman
PostPosted: 15:54 - 29 Jan 2006    Post subject: Reply with quote
poss flooded if enough to turn over yet not to spark aswell,
also if its got a clutch and gears you can bump the thing.
either borrow or buy a new battery then try but id go for bumping first,
ancientd
PostPosted: 16:06 - 29 Jan 2006    Post subject: Reply with quote
When you get it going again, check out the voltage accross the battery when the bike is running at a high tickover, about 2,000 r.p.m. If the voltage is above 13 volts then your Regulator is not working properly and it will kill your battery, if the voltage is less than 12 volts then you may have an altenator fault.
I ride 3 bikes, a Thundercat, an FZRexup 1000 Streetfighter and a Jawa 350 Combo, something for all seasons.
Going2fast
PostPosted: 18:53 - 29 Jan 2006    Post subject: Reply with quote
Thanks for the replies, did finally get her to fire up. Was a flooded problem, once she cleared her troat so to speak all problems with the battery went away, weird.
So got her to the shop for all her nice parts to be fitted. (s/s down pipes, PCIII USB and K&N airfiler Smile )
Thanks again for everyones help. Much appricated
Andy Thumbs Up
/-\ndy
The last post was made 20 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 65.3 Kb
