| jimpuntoy |
 jimpuntoy Nova Slayer
 Posted: 19:47 - 28 Jan 2006 Post subject: nsr125 question carb??? |
i have just taken the carb out and cleaned it and put the slide pin 2nd notch from the end, now i have put it back together and cant remember if it made a tap noise when you close the throttle and when u open it al the way? also it is smoking a lot more now what might i have done ??? |
| jimpuntoy |
 Posted: 20:38 - 28 Jan 2006 Post subject: |
oops would that make it smoke more makin it leaner? what notch do u think it should be on and whats the proper setting for the big screw on the side of the carb? thnx  |
| puremagic72 |
 puremagic72 Brolly Dolly
 Posted: 23:08 - 28 Jan 2006 Post subject: |
if the bikes de restricted( exhaust,airbox), it should be set on 2nd notch from top.
The big screw is the idle(if i remember right), adjust this when the bike is warm, should be 1400. Maybe higher in cold weather(1800)
Small screw to the left of that is screw in as far as can go(not tight) then 2 and half times out
Baz.  ____________________ Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids. |
| jimpuntoy |
 Posted: 11:23 - 29 Jan 2006 Post subject: |
hi, im confused as to which is the top of the slide pin? i will take it the pointed end is, i will try this and adjust the other screw and let u know what happens,, thanks,jim  |
 Posted: 11:41 - 29 Jan 2006 Post subject: |
| jimpuntoy |
 Posted: 11:43 - 29 Jan 2006 Post subject: |
aha i think i know how the slide pin works now as it is tapered it blocks the big jet when you are not turning the throttle and the more you open the throtttle the smaller taper iis exposed allowin more fuel through, and adjusting the set height of the needle allows more or less fuel depending which way you move the clip, so moving the clip towards the point wiill raise it an let more fuel, am i sort of right?  |
The last post was made 20 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
