| DynamiteBoy |
 DynamiteBoy Scooby Slapper
 Posted: 19:27 - 03 Feb 2006 Post subject: Just got back home - bike rescue recovery!! |
After my engine problems on the way into work this morning i was a bit worried about the trip home.
https://www.bikechatforums.com/viewtopic.php?t=73464
This is how it went:
- bike would not start after about 3-4 minutes of kicking
- on second bump the bike started and idled fine
- After 5 minutes riding through country lanes the bike started to 'judder', the engine spluttered (cutting out - through every gear)
- Not long after it completely died and left me coasting into the banking
- Engine wouldn’t start, started walking.
- Five minutes later I approach the top of a nice long hill, get on bump it up, feels fine.
- 2-3 minutes later same happens....engine dies
- Neutral light wont come on, can’t locate first gear...
- PUSH the bike for 3 miles along 60 road, sweating loads (Wales isn’t flat)
- Get to some small village, find local, ring breakdown (cos now I know where I am...)
- Wait 90 minutes before I get home
Its obvious now that I’ve mucked up the carb through my over zealous service....the bike rode back form Swansea to Cardiff ok when i first picked it up....
Because the bike was sitting for almost a year before I bought it I dismantled the carb to clean the jet's...I believe that I haven't put it back together with the correct settings...
I know its my fault and I’ve been asking for a lot of advice lately but the reason i bought this bike was so that I could LEARN with something cheap rather than loose a lot of money in the beginning.
If anyone could point me in the right place I would be grateful, im thinking it’s all down to the mixture - but as you can tell im not to be trusted. Cheers, Ow |
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 19:56 - 03 Feb 2006 Post subject: |
I thought I had it bad when my ZXR kept breaking down and had to push it up hill for about 1km.
Just when things are going great, the damn thing breaks down...AGAIN, dont that just suck
Hope you get it fixed soon, wouldn't want to miss all this cold weather  ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| stinkwheel |
 Posted: 21:52 - 03 Feb 2006 Post subject: |
Just call it a feeling, but your problem sounds electrical to me.
Neutral light not coming on, gradual spluttering and dying.
Sounds to me like a bike that is running off battery power, battery goes flat= start pushing. A bit of rest lets the battery 'recover' for a time.
That said a CG125 shouldn't need a battery at all, produces it's own spark.
I think the neutral light not coming on might be part of it though .
Just going by my ride-out today, bike (GPZ500) cut out a few times then refused to run. Neutral light wasn't coming on. I soon isolated the fault as part of the safety interlock system that stops you operating the starter with the bike in gear and the clutch out. The bike wasn't getting a signal from the neutral switch for some reason and so isolated the ignition (assuming it was in gear).
I fixed this temporarily by jamming a paperclip in the clutch switch terminals convincing the bike that the clutch was pulled in all the time. The fault is on the neutral light circuit somewhere though.
Anyway, back to your bike. It would be worth investigating why the neutral light isn't coming on, could be a similar fault to mine. Is there charge in the battery? Will it kick start with the clutch pulled in? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sickpup |
 sickpup Old Timer
| DynamiteBoy |
| DynamiteBoy |
| sickpup |
 sickpup Old Timer
| stinkwheel |
The last post was made 20 years, 183 days ago. Instead of replying here, would creating a new thread be more useful? |
