electrics help (simple)
cqueen
PostPosted: 14:33 - 05 Feb 2006    Post subject: electrics help (simple) Reply with quote
I know this should be in workshop but I dont have time to wait for an answer and its a pretty simple question.
The cable which connects to the battery on my bike has melted on the exhaust, Ive snipped it off & Im wondering if it will be safe to solder on a new piece of house wire like so...? what with high currents & so.
mr.z
PostPosted: 14:38 - 05 Feb 2006    Post subject: Reply with quote
I woudlnt myself.. unless you know the rateing (something like 60/70amps?
Get down halfrauds or a car shop and get some propper battery cable and terminals
Quite simply isn't worth the risk of seting yourself or your bike on fire
cqueen
PostPosted: 14:42 - 05 Feb 2006    Post subject: Reply with quote
well the other end goes into some black box and I don't really wanna be rooting around in that.
mr.z
PostPosted: 14:47 - 05 Feb 2006    Post subject: Reply with quote
Probably the starter relay..
The wire will be roughly
8mm 105amp
9.2mm 170amp
11.3mm 300amp
depending on the wire thickness..
If you so solder them back together you should use heatshrink to cover the join, and some kind of anti abrasive shelding.. anything less and it will come back to haunt you Shocked
cqueen
PostPosted: 14:55 - 05 Feb 2006    Post subject: Reply with quote
Including insulation its 4mm thick, the wire itself is only 2mm thick, its just a 110cc.
EDIT: oh and on the wiring diagram it says the battery is: 12v - 4Ah if that means anything to you?
mr.z
PostPosted: 15:06 - 05 Feb 2006    Post subject: Reply with quote
Has it got an electric start at all? if not it could be the regulator/rectifier maybe? have you got the wiring diagram on your pc?
I'd still use propper similar sized cable + shielding though, the house cable might take it, but it might not..
Does the wire just dissapear inside this black box or has it got a terminal of some sort?
Teaman
PostPosted: 15:11 - 05 Feb 2006    Post subject: Reply with quote
take the lil bit to halfords and get some more wire, then solder it back together or use chock block,
it will be fine
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
cqueen
PostPosted: 15:15 - 05 Feb 2006    Post subject: Reply with quote
Yeah I only need it for the electric start, otherwise the battery isnt needed at all.
I have got the wiring diagram...
My dad recons I should get a crimping set.
mr.z
PostPosted: 15:16 - 05 Feb 2006    Post subject: Reply with quote
Teaman wrote:
..or use chock block
Exclamation nooooooooo!
Chockblocks are designed to be used indoors, not to get covered in rain, which corrodes the bare wire, that loosens off hits the frame and before you know it your a firework.
Spent hours rewiring when i got my bike cause some twart had used them allover the lights + indicators, of which half no longer worked, several were hanging out where they had frayed, he had "rewired" the bike only 6months before Rolling Eyes
cqueen
PostPosted: 15:17 - 05 Feb 2006    Post subject: Reply with quote
Hey, wouldn't it be cool if someone created an animated wiring diagram, so you can see where it all goes and what it does?!
daz|n00by
The Internet
PostPosted: 15:19 - 05 Feb 2006    Post subject: Reply with quote
Get a crimmping set with higher voltage fittings in m8,
and if your worried about the weather getting at it get some shrink cover,the stuff that shrinks when you apply heat to it .
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
PostPosted: 15:47 - 05 Feb 2006    Post subject: Reply with quote
Housing wire is not flexible or weatherproof enough, you need some proper vehicle wire of the same thickness.
I would solder the two together and shrink-tube over the top. A crimp would be equally effective.
Probably best to make up a whole new bit of wire with a ring terminal on the end and splice it on to what is left, the fewer joints you have, the better.
numark1
Scared of girls
PostPosted: 16:09 - 05 Feb 2006    Post subject: Reply with quote
Or bodge it like i would. Fit any wire you can find, just twist them together and cover it in shit loads of black insulation tape. Cool
Not had a problem yet. Smile
PostPosted: 16:23 - 05 Feb 2006    Post subject: Reply with quote
Then you sell it to me and I get a bad head trying to sort all the marvelous-mystery intermittant electrical faults. Finally land up having to tear it all out and totally rewire the bike. Evil or Very Mad
Method
PostPosted: 17:06 - 05 Feb 2006    Post subject: Reply with quote
WOH Woh Woh woh woh woh woh.....
Chock block = Terminal Block?
If so, your not supposed to use it on bikes?
I have my headlights connected via it due to a certain somebody saying it was better than normal spade/bullet connectors...
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Robby
Dirty Old Man
PostPosted: 17:08 - 05 Feb 2006    Post subject: Reply with quote
Surely someone who does PAT testing should know a little bit about electricity and wiring? Like about electrical fires being bad, that kind of thing.
mr.z
PostPosted: 17:10 - 05 Feb 2006    Post subject: Reply with quote
robby wrote:
...Like about electrical fires being bad, that kind of thing.
Fires that you sit on with a metal tank of petrol between your legs..
cqueen
PostPosted: 17:19 - 05 Feb 2006    Post subject: Reply with quote
I do know a little about wiring, I just wanted to check that it was safe to do.
Hey Robby, why dont you tell me a little something about you?
Because all I know is that you're a cocky cunt.
What do you do for a living? where do you come from? what does you missus look like?
All you do is rear your ugly head once in a while to take the piss.
You fucking prick.
PostPosted: 17:20 - 05 Feb 2006    Post subject: Reply with quote
How to Join Wires
Method
PostPosted: 17:21 - 05 Feb 2006    Post subject: Reply with quote
^^^^^^^^^^^^^^^ Please Answer! Im worried now Laughing
PostPosted: 17:32 - 05 Feb 2006    Post subject: Reply with quote
These? https://www.cse-distributors.co.uk/cabmgmt/images/terminalblocks.jpg
No good. They only hold the wire, not the insulation, the ends of the wires will break off eventually, as well as them going all rusty eventually.
Use non-insulated crimps. You could also use a connector block with non-insulated crimps in it for neatness (like all the other wiring on your bike).
https://www.vehicle-wiring-products.co.uk/VWPweb2000/multicon/photo/mc6.jpg
You can buy all this stuff from www.vehiclewiringproducts.co.uk
nrml76
PostPosted: 17:33 - 05 Feb 2006    Post subject: Reply with quote
If it ain't broke dont fix it. Slap on some insulation tape if you are concerned.
mr.z
PostPosted: 17:47 - 05 Feb 2006    Post subject: Reply with quote
Oh FFS
If you want to fuck up your own electrics then fine, if your bike ends up looking this this its your own stupid twat fault
https://img465.imageshack.us/img465/153/burntbike8tk.jpg
If you dont have any information based on real knowlege then stfu Thumbs Down
This isn't aimed at anyone in particular, but there some pretty dumb ass advice give out sometimes and its a fucking dangeorus as handing out sparklers to kids at a petol station
The Old Geeza
Back in my day...
PostPosted: 17:54 - 05 Feb 2006    Post subject: Re: electrics help (simple) Reply with quote
No problems whatsoever if you solder 2.5mm square cable in place. The only real drawback is that household cable is solid, and could break under movement. Otherwise, just do it Thumbs Up
I just hope you're good at soldering, and that your soldering iron can cope with the temperatures required to join the wires. I personally have no problems, because I have a MetCal soldering station Razz
Me thinks there's a few folks on here just devoted to shit scaring Confused
Horse Power was safer when the Horses had it!
numark1
Scared of girls
PostPosted: 17:56 - 05 Feb 2006    Post subject: Reply with quote
Yeh but thats clearly a one off, just because you join a dodgy wire with just insulating tape doesn't mean the bikes gonna catch fire. Very Happy
The last post was made 20 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 135.75 Kb
