nsr125 exhaust de-coke
jimpuntoy
PostPosted: 14:56 - 05 Feb 2006    Post subject: nsr125 exhaust de-coke Reply with quote
whats the best way to de-coke or whatever clean out the exhaust ? i heard that u would use caustic soda solution but cant find this to buy? are there any other ways to do it or anywhere u can get the sodium hydroxide from? Confused
1992nsr125rk ..
airpig
PostPosted: 18:56 - 05 Feb 2006    Post subject: Reply with quote
You can find it in chemists, no probs Thumbs Up
Bikes are an addiction for which there's no rehab!!
jimpuntoy
PostPosted: 19:00 - 05 Feb 2006    Post subject: Reply with quote
thanks im off to boots tomorro Smile Thumbs Up
1992nsr125rk ..
Chiz
PostPosted: 20:47 - 05 Feb 2006    Post subject: Reply with quote
I used white spirit to clean my exhaust out and it did the trick fine.
fuzz
PostPosted: 20:54 - 05 Feb 2006    Post subject: Reply with quote
Caustic soda will dissolve all of the carbon build up that's sapping power. I need to do this on my NSR, but as I don't use it, I keep putting it off. I don't understand how white spirits will remove 10k miles worth of burnt oil Confused
Chiz
PostPosted: 21:18 - 05 Feb 2006    Post subject: Reply with quote
Well, i don't know if it got rid of all of it. But if you get chain lube on your wheels etc, try using white spirits to clean it off it works a treat. So i thought it would work in the exhaust, poured some down, left it for a while, tipped it out and it was black not clear so it must have got some out.
Bezzer
PostPosted: 21:33 - 05 Feb 2006    Post subject: Reply with quote
That was just a bit of oil it washed out, you need the caustic soda to break down the hardened carboned deposits, if it was a shitty exhaust burning it out with a gas torch is another good method.
magpiemale
PostPosted: 21:57 - 05 Feb 2006    Post subject: Reply with quote
I dont use white spirit on my chain I use parrafin which doesnt ruin the rubber seals on the chain
magpiemale
alains
PostPosted: 00:09 - 06 Feb 2006    Post subject: Reply with quote
use diesel or the fuel you use in heaters . pass onto with a brush several time , let it a couple hours then clean with high pressure water gun . i use this since i begin mechanics in 1962 and it works all the way without destroying rubbers
The last post was made 20 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 58.9 Kb
