Trouble Finding race pipe. and Speedo Query
davidkent89
PostPosted: 21:15 - 05 Feb 2006    Post subject: Trouble Finding race pipe. and Speedo Query Reply with quote
Me again Rolling Eyes
I'm having trouble finding the right Leo Vince ZX for my ped.
I'm having trouble, because my Ped has the CAT System, and so i don't know how to go about it.
If i remove the system, then i would surely have a hole in the carb? or to that effect, and also need to upjet it, yet if i don't remove it, there would be a loose pipe doing nothing but taking in air?
Anyone got any ideas?
Also, is it possible to get a new speedo card? as in just the bit of card with the numbers on it?
one that goes higher than 50 mph, but the numbers up to that are evenly spaced out the same as the original?
David
Chiz
PostPosted: 21:39 - 05 Feb 2006    Post subject: Reply with quote
The CAT is in the exhaust not the carb. I don't know about rejetting but none of my mates ever rejetted after derestricting and they're all going fine. *Touch wood*
If the exhaust is standard then they tend to be be pretty restrictive so just a new exhaust should do the job. You won't need a speedo that goes higher than 50 (unless you live at the top of a hill Laughing )
J.K.R
PostPosted: 21:48 - 05 Feb 2006    Post subject: Reply with quote
Help if we knew which scooter it was Rolling Eyes Cat usually sits above the flywheel cover, im sure you block it off when you put a different exhaust on it (or take it right off)
You will need to upjet though, Usually just a couple of sizes Wink
www.oldskoolsuzuki.info
davidkent89
PostPosted: 22:01 - 05 Feb 2006    Post subject: Reply with quote
Its an NRG LC 2004 Model.
I do need a higher speedo card, it goes over the 50 mark as it stands!
David
palmer
Fiddled Kiddy
PostPosted: 22:04 - 05 Feb 2006    Post subject: Reply with quote
I took the end pipe off my rs (got a cat in it) and havent done anything to the carb.
would it need leaning a little?
Jack_Cheese
PostPosted: 00:44 - 06 Feb 2006    Post subject: Reply with quote
The pipe isn't a cat, it's an air recirc. You HAVE to rip it out. If i were you, i'd just get a garage to fit the exhaust. It will definitely need rejetting, too.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
davidkent89
PostPosted: 18:20 - 06 Feb 2006    Post subject: Reply with quote
Jack
Apparently there is a way it can just be blocked up though?
David
Jack_Cheese
PostPosted: 22:38 - 06 Feb 2006    Post subject: Reply with quote
the problem then is you end up with pipes flapping around, if you remove the pipe and put a cover over where it enters the carb, you should be ok.
Jack
davidkent89
PostPosted: 22:43 - 06 Feb 2006    Post subject: Reply with quote
Thats true, unless i get it removed, and then sell the entire system to make some money back lol
davidkent89
PostPosted: 22:45 - 06 Feb 2006    Post subject: Reply with quote
Also, www.sip-scootershop.com sell the leo vince i need chrome Zx for NRG LC 2001 and newer version and so on, for £80, however i'm unsure as to whether it will come with the rollers, clutch springs, bolts and jet or everything i need.
David
Jack_Cheese
PostPosted: 18:01 - 07 Feb 2006    Post subject: Reply with quote
it should come with rollers, the leovinces normally do.
Jack
Hoffy
PostPosted: 19:36 - 07 Feb 2006    Post subject: Reply with quote
You sure your clock aint in KM/H ?? 50KM/H is roughly 30MPH so that would be about right for a restricted ped ..........
Take Care
Alec
Plagued by 1980s Suzuki 2 strokes !
davidkent89
PostPosted: 20:16 - 07 Feb 2006    Post subject: Reply with quote
Its derestricted.
80KMH and 50MPH
David
The last post was made 20 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 76.16 Kb
