frame number
Biker_Dene
PostPosted: 12:32 - 07 Feb 2006    Post subject: frame number Reply with quote
trying to get the log books sorted for my gt 185
but i vant find the frame number anywhere on the bike
where would it useualy be? and what if its been removed?
J.K.R
PostPosted: 12:37 - 07 Feb 2006    Post subject: Reply with quote
It tends to be up on the right hand side of the headstock (if you were sitting on it) Wink
If its not there, im sure all you can do is buy another frame with a V5 Confused
HTH Thumbs Up
www.oldskoolsuzuki.info
syl
PostPosted: 12:39 - 07 Feb 2006    Post subject: Re: frame number Reply with quote
Afraid I have no idea on this. I was looking for the frame number on my bike recently (to fill in the datatag forms). The registration number (obviously) and engine numbers were easily visible but for the VIN/frame number I went back to the V5 (doesn't help you).
A quick search suggests that some manufacturers stamp them on the frame near the steering head (on the R side).
Current bike: Kawasaki Z750S
Biker_Dene
PostPosted: 14:49 - 09 Feb 2006    Post subject: Reply with quote
trying to get the books sorted on my gt185
but all i can find is the engine number
the log book form asks for the chassis/frame/ engine /or vin number
all i can find is the engine and i dont know what a vin is lol
will it be ok to only use the engine number as thats all i can find
atleast i think it is, its only 5 numbers (gt185 27**0)
BlackSheep
PostPosted: 15:18 - 09 Feb 2006    Post subject: Reply with quote
It is stamped into the headstock.
GSXR 1100 StreetFighter
Biker_Dene
PostPosted: 15:22 - 09 Feb 2006    Post subject: Reply with quote
nope nothing there as i have said
no vin number plate no chassis number no frame number
only an engine number
guess ill have to re register it
the bike is very old tho year 1974
lllN30lll
PostPosted: 15:25 - 09 Feb 2006    Post subject: Reply with quote
A Vehicle Identification Number (VIN or chassis number) is required on all vehicles first used on or after 1 August 1980. except those which are
. kit cars
. amateur built vehicles
If a VIN cannot be found the vehicle presenter should be advised of the likely location of the VIN and to thoroughly search for the number with the aid of the registration document. If following this action the VIN cannot be found the vehicle presenter should contact the nearest Vehicle Registration Office.
If more than one different VIN is found, the vehicle presenter should contact the nearest Vehicle Registration Office.
Turbo R1
CRF450R
BlackSheep
PostPosted: 17:41 - 09 Feb 2006    Post subject: Reply with quote
It's probably still there on the headstock but painted over enough to hide it (i have seen this loads of times on old bikes) definatley worth rubbing the headstock down to see if it's there.
Biker_Dene
PostPosted: 18:14 - 09 Feb 2006    Post subject: Reply with quote
scared ill rub it off lol
theres alot of paint and if i sand the piant off i could end up smoothing the metal and rubbing it off
might try getting soem paint stripper.
Nath
PostPosted: 19:13 - 09 Feb 2006    Post subject: Reply with quote
Just use some wirewool, or mediumish wet and dry. Unless go mad with something heavy-duty you will not sand away the frame number.
Hard livin', hard luck.
R6 JACK
PostPosted: 10:51 - 10 Feb 2006    Post subject: Reply with quote
hey while were on the subject should the engien and frame numbers match when new?
JAck
The last post was made 20 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 66.81 Kb
