Would you welcome ABS?
veeeffarr
PostPosted: 22:03 - 07 Feb 2006    Post subject: Would you welcome ABS? Reply with quote
ABS on bikes, if it was an option on most bikes would you take it?
I think I would personally, anything that makes motorcycling that little bit safer is great in my opinion. You could argue that it removes rider skill, but I think that it is for the better, and personally would like to see ABS as an option on mainstream motorcycles.
Thoughts?
Toby
Sparks!
Sir Tart-a-lot
PostPosted: 22:05 - 07 Feb 2006    Post subject: Reply with quote
No way!! Wouldn't be able to do stoppies!
R4nger
I can imagine a person doing a burnout on a ABS bike and the front sides abit from the grip and then the ABS releasing the brakes Laughing
mchaggis
PostPosted: 22:06 - 07 Feb 2006    Post subject: Reply with quote
Yes, ABS is categorically a good thing in the hands of the untrained and the hamfisted. Anyone who has binned their bike due to locking the front on a slimey surface will understand. It can be a very useful device, even if there are situations in which it does not produce absolutely optimum braking.
I must not be a troll...
Mmmm, Guinness
PostPosted: 22:09 - 07 Feb 2006    Post subject: Reply with quote
Has anyone got experience of ABS - one problem I can see is that it could give you a false sense of confidence as I would expect it to be a lot less effective than car ABS.
Have ridden a bike with ABS, but as it was at Brands Hatch in the fast group, I didn't want to try it out really Smile (obviously no problems with grip normally).
Suzuki
Roger
PostPosted: 22:11 - 07 Feb 2006    Post subject: Reply with quote
I wish my car DIDN'T have ABS. It pisses me off.
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
PostPosted: 22:15 - 07 Feb 2006    Post subject: Reply with quote
Something else to go wrong.
I like the simple directness of the engineering on motorcycle brakes. Either lever pulls cable, moves shoes into contact with drum. Or lever pumps piston, moves other piston which pushes pads against disc.
I don't like the idea of lever pumps piston, sensor checks wheel, computer decides if wheel moving. IF wheelmoving=1 applybrake ELSE nobrake; ENDIF: . Pushes piston against brake pads.
Something in common with every computer I have ever used (even very basic ones which are little more than a series of transistors) is that at some point they stop working for no apparent reason. Now you usually just have to reset them to get them working again...
Same reason I wont buy a bike with fuel injection, inherantly dislike the idea of CDI (although it is difficult to avoid) and disconnect all the idiot switches on my bikes.
Brava210
PostPosted: 22:24 - 07 Feb 2006    Post subject: Reply with quote
mines got ABS though i havn't used it YET Smile
Honda Novio, Puch Grand Prix, Suzuki AP50, CZ 125, Wassell 125, Montesa 348,Honda 125TDC, Suzuki 100ER, Suzuki GSF650 Bandit, Aprillia Pegaso, Honda PCX125, Honda Forza300, BMW G310 GS, Suzuki SFV650, Honda CB500X
CHARLEY SAYS " ALWAYS TELL YOUR MUMMY BEFORE YOU GO OFF SOMEWHERE"
Jack_Cheese
PostPosted: 22:25 - 07 Feb 2006    Post subject: Reply with quote
Jebus, you're right. I think traction control would be a worthwhile acompaniment to abs. Though singe i don't do burnouts, stoppies etc, i'd rather have ABS on a winter hack simply because i know i'm probably going down the road without it.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
Simple
PostPosted: 22:27 - 07 Feb 2006    Post subject: Reply with quote
I don't like the idea, besides locking the rear wheel up is fun Laughing
If I went to look at 2 second hand bikes, both the same in every way except one had ABS, I'd take the one without, imo just something else to go wrong.
simple
Insta - FemFeral
Visitor Q
$25 whore
PostPosted: 22:30 - 07 Feb 2006    Post subject: Reply with quote
You can turn them off you know.
A mate on his beamer apparently only avoided a crash because of abs, he got forced into a concrete barrier at speed which jammed the rear brake on. IF he hadnt had ABS it would have kicked him off.
Danny
Ask Me About Stoppie School
PostPosted: 22:37 - 07 Feb 2006    Post subject: Reply with quote
I would like ABS only if you could turn it off;
the fact that it makes servicing more expensive and difficult is a big down side though.
Zimbo
PostPosted: 23:00 - 07 Feb 2006    Post subject: Reply with quote
There is some evidence that ABS on a bike is actually LESS safe.
When I think about it, when was the last time I locked up the front wheel under heavy braking? Nope, don't recall that I ever have . . .
So, not for me thanks.
veeeffarr
PostPosted: 23:02 - 07 Feb 2006    Post subject: Reply with quote
Interesting.
What's the general consensus on motorcycle safety in general?
If motorcycling was MUCH MUCH safer (IE: risks of death comparable or less than in a car) Would you still ride? Would it be boring without the danger aspect?
Personally, I would love riding to be as safe as it can be, it's not the danger I enjoy.
Toby
fuzz
PostPosted: 23:07 - 07 Feb 2006    Post subject: Reply with quote
On my test Razz
Not since... So no, I wouldn't go for it. How about CBS? Again, I would rather have full control over both brakes. I don't like the idea of something going wrong, and having the rear lock up when I'm only using the front brake.
Lone-Wolf
PostPosted: 23:09 - 07 Feb 2006    Post subject: Reply with quote
Wotcha.
ABS ain't new.
My old sidevalve BSA outfit ( 7 inch drum front - 6 inch drum rear ) wouldn't lock the wheels no matter how hard you squeezed that lever or stood on that pedal. . . . . . and take it from me, with a trailer behind it, a passenger in the chair it put a whole new meaning to the words "safe braking distance" Wink
Poor brakes and poor lights are two of the things I would not like to go back to - - not all progress is bad.
Cheers.
L.W. - www.moonshiners.org.uk
veeeffarr
PostPosted: 23:12 - 07 Feb 2006    Post subject: Reply with quote
Lone-Wolf wrote:
Wotcha.
ABS ain't new.
Don't buy a CG then Smile
www.125power.com
PostPosted: 23:20 - 07 Feb 2006    Post subject: Reply with quote
I thought ABS would help with stoppies as it has nothing to do with fork-dive. ABS or Anti-Lock Bracking System simply backs of the brakes slightly as it detects wheel lock. Modern ABS sytems do this so fast you never knew the wheel actually engaged a full lock condition because it happens in a 100/th of a second and is corrected in 2-6 100/th's of a second later depending on the system. not being able to lock the front wheel is great for stoppies
Not being able to lock the back wheel can be a pain in the arse when you want fun.
Front ABS will asist rolling burn-outs too as it stops the front wheel jittering along the tarmac or just locking and skidding....but you will be more likely to move quicker as the abs backs of the brakes as the wheel locks and you will probably start picking up speed without realising
My eBay Items
PostPosted: 23:25 - 07 Feb 2006    Post subject: Reply with quote
Zimbo wrote:
When I think about it, when was the last time I locked up the front wheel under heavy braking? Nope, don't recall that I ever have . . . .
But is that because you know it is likely to happen so only use (say) 50% of the possible braking power in an emergency?
Personally I think it would depend on what the bike was being used for. Winter riding to work then I would appreciate it. In a way it is more important on a bike than a car, because if you lock the front wheel you are likely to come off. On the other hand a car only has a single brake control for 4 wheels, and each of those 4 wheels has a different level of grip available to it.
PostPosted: 23:26 - 07 Feb 2006    Post subject: Reply with quote
I believe ABS detects the differences between wheel speed?
In a stoppy there would be a difference in wheel speed unless you were very good with the throttle at the same time.
In a similar manner it should stop rolling burnouts
Toby:
If I believed it would actually help safety on the bikes I ride and it was no extra cost, I would have it.
I'm not convinced that it will so far.
Suzuki:
Out of interest, why don't you want it in the car?
I've been hankering after a car with ABS for a while.
PostPosted: 23:45 - 07 Feb 2006    Post subject: Reply with quote
Hi G
They should partly work on the difference in wheel speeds, but also on the max deceleration that the wheel should manage (so if it exceeds that then it thinks it is locking).
ABS in cars does increase the stopping distance. Trouble is that the time ABS is useful is when something unexpected happens and people panic brake. At which point the ABS will easily outperform someone with fried egg eyes and locked wheels.
Also the ABS in some cars seems to cut in very early (certainly does in our 155), and some cars have fairly limited ABS (quite often the rear wheels are treated as the same, so one locks and the other has the brakes backed off as well).
www.125power.com
PostPosted: 23:49 - 07 Feb 2006    Post subject: Reply with quote
ABS simply keeps your brakes from locking up. On Bikes not equipped with ABS, the rider can manually pump the brakes to prevent wheel lockup or not pull the lever as hard. In vehicles equipped with ABS, the rider remains firmly on the brake lever as hard as he/she likes, allowing the system to automatically pump the brakes (so quick you dont feel it or feel any surges under heavy braking) the result is a continuisly varying presure on the pads nd thus they cannot lock the disc but slow it very fast.
SO where is the need for the ABS to be connected to the throttle????
Also on ice can increase your stopping distance over a "controled skid" i would rather ABS or Gentle manual braking than attempting to skid to a stop.
My eBay Items
Jack_Cheese
PostPosted: 23:55 - 07 Feb 2006    Post subject: Reply with quote
The system monitors wheel speeds, so when one stops straight away, it knows it's locked, and releases instantly, but the time taken is miniscule, so you don't notice it.
Jack
craigs23
Mr Muscle
PostPosted: 00:01 - 08 Feb 2006    Post subject: Reply with quote
Agreed - if I was to buy a bike with ABS, like others have already mentioned, I'd like to switch it on or off depending on conditions. Personally, I don't like the notion of emergency stops in the wet. Yes, I have done them and haven't come off, even with the front wheel locking, but usually, it's an area I don't 'enjoy'.
Also, whilst I'm at it, I'd like to have electronically adjustable suspension for wet/dry conditions (just presets, so I can mess up my suspension settings if I felt the need), plus high/low states of engine tune to (doesn't one of the new Benelli TNT's cater for this?)
kb-zxr
PostPosted: 00:06 - 08 Feb 2006    Post subject: Reply with quote
I reckon it would be useful for the front wheel at least. Stoppies might still be possible as the front wheel just doesn't stop at once afaik.
I wouldn't like linked brakes though, I would like to operate both independantly.
The last post was made 20 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 133.97 Kb
